04-03-2010, 11:45 PM | #1 |
700R auto transmission for C10 69
Finally: yesterday I started to collect all the necessary parts in order to converting, four speed compound manual into 700R4 A/transmission my C10longbed stepside 69 .
Things I already have are: 700r4 transmission converter flywheel starter braket for tv cable and acelerator Things I´m missing, unless I´m forgetting something. crossmember shifter system. oil lines On the following days I´ll be asking questiions and sugestions. If you have a post where I can see how you did it I´d like to take a look. Now I´ve some questions: Can I use any crossmember from 82-87 truck , equiped whit 700R4? could I install a Camaro shifter system? if a member of this forum did it can you give ideas. thank you |
04-04-2010, 06:58 AM | #2 |
Watch out for your cornhole !
Re: 700R auto transmission for C10 69
Don't forget the trans mount and metric bolts for it as well as the starter bolts.
04-04-2010, 11:21 AM | #3 |
Thanks TX: because I took everything of a Van C20, I saved every single nut and lug.
The trans mount is on the tranny but I´m not sure if is the same for car,van and truck. Also:could any floor shifter system of a vehicle with 700r4 be a donnor thanks |
04-04-2010, 12:09 PM | #4 |
Before starting to do anything, I just took a look for which parts need to be removed, and I notice the old transmission is hold on what I think is a crossmember.
Do I need to remove that crossmember? I Know I need to install a new and the new is going to be more at the back. |
04-04-2010, 02:43 PM | #5 |
member #16
Yes you need to remove the std trans crossmember. You will need a auto trans radiator for the cooler,and cooler lines.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 04-04-2010 at 02:44 PM. |
04-05-2010, 12:10 AM | #6 |
Thanks all of you: I´ve been reading the information you send me as well as in FAQ section.
04-12-2010, 12:52 AM | #7 |
OK this weekend I picked up shifter from a Montero Sport and cable from a Camaro. I noticed I need to make a little modification, I still nedding oil lines, trans cooler and crossmember. I said I took the transmission from a Chevy Van and I noticed crossmember is different from a truck and truck and suburban look for me the same.
Could I install one of Suburban? Also some trucks and suburban they have 350s,400s or other auto/trans. 81s and old I think. Is the same crossmember? One more question: Is there any difference in performance using camaro,truck, van or suburban converter or all are the same? Thanks for your pattience on my questions, I´m not a mechanic but I want to learn. |
06-12-2010, 09:21 PM | #8 |
what do u plan to use for a speedo cable? i am in this situation on my truck. i have no speedo cable for my 71 with a 700r4.
06-13-2010, 02:52 AM | #9 |
Well: if you are asking about speedometer cable, I still needing a cable because the original cable is too short and 350s tranys are shorter than 700s anyways, I can't use one of 350s and 700s tranys are at 82 and newer trucks and the ends(terminals, are different)
May be a member can give us ideas. |
06-13-2010, 06:40 AM | #10 |
Check with NAPA. I bought a longer cable there for my 66 when I changed transmissions some years ago.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
06-13-2010, 12:12 PM | #11 |
my 700r4 is newer and requires a conversion gear (speedo bullet) on the output shaft to use the original speedo. Personally I'm just going to upgrade to an electric speedo.
but if you want to go through the motions: http://www.transmissioncenter.net/sp...n_______va.htm You can probably find most of what you need at a wrecking yard. I'd like to mention as well, the guy I bought my truck from has hooked up 4th gear to a toggle switch under the dash. I've heard that you can pull a vacuum overdrive control from a late model burb or tahoe. Any one know what the parts are called?
Looking for a short fleetside bed in the Pacnorthwest/western Canada. Last edited by Deggs; 06-13-2010 at 12:14 PM. |
06-13-2010, 02:17 PM | #12 |
gmc1971harwich: I'm not sure if you get the answer to your question
06-13-2010, 03:19 PM | #13 |
I did the swap. You also need to look at the parts to run the converter lockup.
here is a link to a pic of the vacume switch in the faq section http://67-72chevytrucks.com/vboard/a...1&d=1117260504 some added parts you might need. -a lock up converter -the electrical harness which plugs into the trans. -a brake switch with two contacts -and the vac switch wiring. You can grab all these at a salvage yard. This might change depending on how you actually decide to hook it up. I will see if I can find the article explaining the. brake, vacume, toggle switch method. |
06-13-2010, 04:32 PM | #14 |
Your UncleBen
I have not heard any speak of the TV cable? Dont run a 700 without one!...
68 C10 shortbed -- Street/Strip |
06-13-2010, 05:04 PM | #15 |
Thread Tools | |
Display Modes | |
