Old 04-15-2010, 08:54 AM   #1
vtwinsport
vtwinsport's Avatar
Oil pressure up then down
Hey all,
recently my engine psi has been up around 50 psi from normal 20 at idle. Doesn't seem to make a difference if its warm or cold, been parked or been running.
motor only has 6000 miles on it. rebuilt by a shop tied to 350 turbo that seems to be working fine.
Any ideas what's going on? Something about to break?
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 04-15-2010, 08:56 AM   #2
Jonboy
Slots go on anything!
Re: Oil pressure up then down
I would try another gauge before you start pulling everything apart. Maybe try a cheap aftermarket gauge just to confirm.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-15-2010, 09:17 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
could be the sender unit too those go bad far more often than the guages.. is it electrical or is it mechanical?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-15-2010, 10:20 AM   #4
Jonboy
76 is still a mechanical gauge.
Old 04-15-2010, 12:08 PM   #5
vtwinsport
vtwinsport's Avatar
thanks guys- good ideas
I actually have a mechanical Autometer in there. Guage is 1 year old. Me thinks it could be the sender now that you'll brought it up.
Old 04-15-2010, 08:07 PM   #6
Colesnsty68
Colesnsty68's Avatar
is it bad that mines done that since the day i put it in? seems to run fine, jw.
1970 Chevrolet custom camper 20
2000 F@$d F250 Powerjoke
"And i still like bologna on white bread now and then" -Alan Jackson
Colesnsty68 is offline   Reply With Quote
Old 04-15-2010, 09:00 PM   #7
harnalien
TruckincrazY
harnalien's Avatar
Mine too!!
harnalien is offline   Reply With Quote
Old 04-17-2010, 02:21 PM   #8
Colesnsty68
It only does it at lights, just at a lower rpm so i figure its just the pump aint pumpin so fast, any other ideas? i know its not bad, just would like to know.
Old 04-17-2010, 04:22 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea that's what I was thinking as well.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-17-2010, 07:15 PM   #10
Panelman55
Panelman55's Avatar
When did you last change the oil??? What oil are you using??
In God We trust!!!
Panelman55 is offline   Reply With Quote
Old 04-17-2010, 07:17 PM   #11
Colesnsty68
About three weeks ago, its always done, castrol gtx 10w 40.
Old 04-17-2010, 08:09 PM   #12
LONGHAIR
A pressure increase is odd.
Filter failure?
Pressure regulator stuck? I wouldn't think so at idle, but?
Spin a cam bearing?
Is the top-end still oiling ok?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-17-2010, 08:40 PM   #13
Colesnsty68
oh yah everythings just fine, it runs great, so who knows.
Old 04-18-2010, 03:09 AM   #14
spinem
haha, ford guys...
if its electrical id check all grounds. did you use sensor safe selant on the sensor? (not all "sensor safe" sealants conduct.)
spinem is offline   Reply With Quote
Old 04-18-2010, 07:03 AM   #15
LONGHAIR
Colesnsty68, this thread is the exact reason that it is against the rules to "Hi-jack" someone elses thread. You jumped in after the last response of the original poster and have continued to answer and give details....confusing the heck out of this thread.
Unless a responder "knows" the OP pretty well, it goes unnoticed that the person asking questions and giving details has changed.
Old 04-23-2010, 08:52 AM   #16
vtwinsport
vtwinsport's Avatar
thanks longhair. I was thinking about that.
Anyway, checked my lines and fittings, no leaks, checked oil level, checked top end under valve covers- all appears fine but I'm no 20 year mechanic.
Oil pump, guage, lines and sending unit are 1 year old.
It is still doing it, though I think the high pressure at idle is related to core block temperature- like metal temperature. I have noticed that after 20 minutes of driving the pressure started behaving normally- 20 psi at idle, 60 at hwy speeds.
Is this indicative of a bearing issue since the oil pressure drops after the journals and good and warm or an oil type- pump issue? I'm running 10w-30 & penzoil filter. I guess I'll try a new sender and an oil/ filter change first as it cost so little and see what happens.
thanks in advance
Old 04-23-2010, 10:27 AM   #17
raws67
raws67's Avatar
If its a mechanical gauge it shouldnt have a sending unit should it? Another thing to look at may be crud in the line or gauge itself maybee some thread tape or something like that.
raws67 is offline   Reply With Quote
Old 04-23-2010, 11:54 AM   #18
vtwinsport
vtwinsport's Avatar
I was thinking of the brass fitting that threads into the block. I guess its not really a sending unit.
That's agood suggestion as well, remove the lines and fittings and clear them with compressed air.
Old 04-23-2010, 11:02 PM   #19
Colesnsty68
My MF'in bad.
Old 04-23-2010, 11:03 PM   #20
Colesnsty68
Also, Vtwinsport, my deepest apologies for Hi-jackin yalls thread.
Old 04-25-2010, 09:10 PM   #21
vtwinsport
vtwinsport's Avatar
No problem Colesnsty68,
It happens. I've caught myself a few times doing the same.
Cleaned the oil lines and brass connection at block with air. Will take it for a test run and see if did anything later.
Old 04-25-2010, 09:57 PM   #22
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
As far as i know its normal for the oil pressure to rise and lower at different rpms, it builds up pressure as the motor revs. as long as it doesnt stay low im pretty sure youre alright.
staggerd86c-10 is offline   Reply With Quote
Thread Tools
Display Modes
