Old 04-15-2010, 06:42 PM   #1
skeeterbug
skeeterbug's Avatar
manual to power brake question?
hello all, i am in need of some input from those of you whom have done this upgrade already please. i have a 71 c10 lwb that i have doing a frame off on and need some suggestions to convert it from maual to power booster brakes. before i tore the truck down i purchased a complete ss brake line set from LMC, it has all fit fairly well till i started plumbing the lines from the mastercylinder to the front crossmember. the master cylinder and prop. valve that came w/ my truck i belive came off a earlier model c10 and will not work w/ the new ss lines. i have since picked up a donor mastercylinder from my fathers '56 belair rebuild we never used, its better but the ss lines still will not hook up correctly to the old prop. valve i have. to make a long story short i have decided to go w/ captain fabs disk conversion brackets, willwood d52 calipers, and astro van AWD rotors for the rear. for the front i will get two more d52 willwood calipers and cptain fabs booster braket, but i need to know what prop valve and booster to get. will the stock 71-72 style prop valve work or will i need to get a disc/disc prop valve, please help i might as well do all this s@#$ while its this far down and needing a different valve anyway.
thanks
skeeterbug
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Thread Tools
Display Modes
