Old 04-16-2010, 09:43 AM   #1
norske
Differential clunk noise in reverse
Lifted the bed off my 68 Chevy c10 and decided that's the best time to change the pinion seal, change the differential fluid, and check u-joints. The pinion seal appered to be leaking, so replaced it. All the u-joints were no good, put in all 3 of them. It's a 2-piece driveshaft with the carrier bearing (that was ok). The rear end is a 12-bolt with 8 7/8" ring gear, says GM56 on it. Talked to a guy who works on the local dirt track circuit and he said there was no preload on the pinion nut, just rattle it back on. When I got finished, backed it out of the shop and noticed the rear end (I think) seems to bind and "clunk" in reverse. It doesn't do it going forward. I don't know if it did it before or not. There was just the nut and washer on the pinion. Could I have done something wrong (There is a preload on the pinion nut?) or maybe a problem that I just didn't notice before? Going to jack it up and spin the wheels and see what's up. Any ideas appreciated.
norske is offline   Reply With Quote
Old 04-16-2010, 09:51 AM   #2
neba
Re: Differential clunk noise in reverse
bad advise from local gearhead. there are books full of information on what is needed to check wear patterns, shim, and torque to specs.
neba is offline   Reply With Quote
Old 04-16-2010, 10:38 AM   #3
425HP409
425hp409
425HP409's Avatar
Ditto, bad idea from gearhead. You must install the pinion nut EXACTLY in the same place that it was before to prevent problems. When it was installed, it was torqued to crush the crush sleeve on the pinion shaft. You must put the nut back on to have the exact preload that it originally had. If it is too tight, you will demolish the pinion bearings. If it is too loose, you will have slop in the pinion, which will demolish the ring and pinion. You may try to tighten it up so that you just eliminate the slop in the pinion, front to back. Good Luck
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 04-16-2010, 10:46 AM   #4
cdowns
cdowns's Avatar
the factory solution was called a service manual//availabe at very cheap prices from most board vendors
Old 04-16-2010, 11:05 AM   #5
norske
It absolutely makes sense that a tight nut would wreck the bearing and a loose nut would wreck the gears. Think I'm going to back it off and take out the slop and call it good. We'll see if the binding stops.
Old 04-16-2010, 11:09 AM   #6
LONGHAIR
As much as I always advise that people not mess with rear ends, it is doubtfull that you really screwed-up anything doing this. Simply removing the pinion yoke and swapping the seal should not cause any major issues. The pinion bearings are indeed "preloaded" and that "adjustment" is controlled by a crush sleeve. These crush sleeves are notoriously hard to crush, more-so when they are new, but even after being "set". Even if you did over-crush it, that would not cause a clunk, it bad (potentailly very bad) but not a clunk.
At this point "shims" and "wear patterns" are a moot point. Those things are already set and cannot be changed. That's a "one time" deal.
Pop the cover off of that thing and have a look inside, post pictures if you have questions about what you see....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-16-2010, 03:03 PM   #7
Shaky
Six in a row makes it go...
Shaky's Avatar
My buddy had a reverse "clunk" in his '69. Turned out to be a rusted out U-bolt for the trailing arm. It failed on I-95 during rush hour.
Check your arms first and then go to the rear. Oh yeah, that gearhead advice was not good...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-19-2010, 01:33 PM   #8
norske
Ok, I got it. That nut goes on hard, I didn't have it up there tight enough. Tightened it up to the crush sleeve, then bumped it back until there was just a hair play. she's nice and quiet now.
Thread Tools
Display Modes
