Old 04-16-2010, 09:10 PM   #1
100mph
Does your Grille get hot?
Anyone notice their grille getting fairly hot after only a short drive?
I'm just finishing putting together my 69 SWB 402BB and took it out for a 10 minute run, idled for a few minutes, shut it off, went to pop the hood and the grille was almost too hot to touch.
Water temp was reading normal, fan was sucking in (thought maybe it was blowing out) and otherwise everything else seemed fine.
Is this normal? Is it just acting like a big aluminum heat sink?
Thanks!!
100mph is offline   Reply With Quote
Old 04-16-2010, 09:14 PM   #2
bigguy69
dazed and confused
bigguy69's Avatar
Re: Does your Grille get hot?
i wouldnt think that would be normal.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-17-2010, 12:20 AM   #3
100mph
Thanks... so yours doesn't get hot?
Old 04-17-2010, 12:24 AM   #4
'72customdeluxe
Mine doesn't at all
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 04-17-2010, 12:31 AM   #5
mdwilf
mdwilf's Avatar
I wonder if it is getting hot from an electrical short? My first thought was "fan blowing wrong way", but you said that was not the case.
What I do in my spare time:
http://rosebudsgarage.shutterfly.com
mdwilf is offline   Reply With Quote
Old 04-17-2010, 10:39 AM   #6
100mph
hmmm.... yeah, fan is sucking in, nice and cool between the grille and rad and I'd assume an electrical short would have done more than heat up the grille (like catch something on fire or at least blow a fuse).
Raining here now but I'll take it out again and try to figure it out but if anyone else has any input or suggestions I'd love to hear it.
Old 04-17-2010, 10:56 AM   #7
dan42
dan42's Avatar
Mine does not get hot either - is there any way something it is touching something that is conducting the heat from the motor?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-17-2010, 11:12 AM   #8
100mph
That's kind of what I'm starting to think but what would be different about mine than yours?
The rad and rad support get pretty hot too which is pretty normal (I think?) - did I miss some insulating 'mounts' for the grill, is the hood latch just conducting the heat from the rad support to the grille?
Just can't figure out why I appear to be the only one??
Old 04-17-2010, 11:25 AM   #9
pat 70/71
pat 70/71's Avatar
how hot is your weather at the time this is happening? would understand the outer grille getting hot from the sun? I would try wrapping the headers maybe larger cfm fan? best of luck, Pat " my grille does not get hot " are you running a shroud?
pat 70/71 is offline   Reply With Quote
Old 04-17-2010, 11:26 AM   #10
GruntMoanCough
GruntMoanCough's Avatar
Maybe post a pic or two, someone might see something wrong. Just a thought.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 04-17-2010, 11:40 AM   #11
100mph
Outside temp is about 65F and not sunny at all. Running an electric fan that seems to keep the engine temp normal and running stock manifolds (for now).
I appreciate everyone's input!! I'll take it out this week with a temp gun and see if I can't trace the heat backwards from the grille - the heats got to be just transferring through to the grille but the mystery is why just on mine???
Old 04-17-2010, 12:47 PM   #12
LowBow
Self Made Hundredaire
LowBow's Avatar
is it a factory grill or aftermarket metal piece?
'79 corvette - all original 49k car!
'03 Z71 ECSB - gas hog
'57 Belair 2 door hardtop. Love of my life!
LowBow is offline   Reply With Quote
Old 04-17-2010, 01:06 PM   #13
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
X2.
Hard to figure out without a pic.
I have never noticed the grill on my 71 getting too hot to touch.
305 with stock manifolds and I don't run a shroud.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 04-17-2010, 01:33 PM   #14
pat 70/71
pat 70/71's Avatar
Hey 100 mph, just a quick note, the main electrical to the cab runs over the core support. it could be that your wire loom has a short & somewhere its contacting metal. try to go over that section of the loom you might find the short . thats where I would look first. best of luck, Pat
Old 04-17-2010, 01:48 PM   #15
chevysittinsidewayz
good thought, just turn the key on and wait to see if the grille gets hot, if not i would make sure coolant isn't staying stagnant in the radiator after the engine warms up; even if its only moving a little it could heat up the aluminum grille
whoever thought of "i live my life a quater mile at a time"-vin diesel needs to be ***** slapped. i would have a pretty short life
chevysittinsidewayz is offline   Reply With Quote
Old 04-17-2010, 04:25 PM   #16
bigguy69
dazed and confused
bigguy69's Avatar
i am with everybody else, i would look for a short myself. i have run the trucks i owned pretty hard before and popped the hood. didnt feel hot. i would unhook the battery if it is going to be sittin for awhile. i would hate for it to start a fire and burn down your truck until you could figure out what it is.
Old 04-17-2010, 07:18 PM   #17
Does just the grille get hot?Is the core support hot?And,if it`s some crazy short it should get hot w/o the motor running,right?
Old 04-17-2010, 07:31 PM   #18
100mph
Thanks guys!!
I'll look for an electrical issue but it's all new wiring and have had that much together for months and never noticed anything till I took it out for a run
core support is hot too bit figured that's normal??
I'll get back to the shop (it's at my buddies) and investigate more
I'll post back what I find during the week
thanks again!!
Old 04-17-2010, 07:32 PM   #19
vectorit
What?
vectorit's Avatar
Mine doesn't get hot at all.
But, have you made sure that your radiator rubber bushings are good? These are the rubber troughs that the rad sits in, and then there are two on the top as well.
Just throwing this idea out there too. But do you have the stock cast iron exhaust? If so, do you know if the heat transfer flap is working correctly? This is the flap that is on the passenger side, and is opened with a thermostatic spring once the engine temp has reached it's trigger point. If it's broken, or stuck then I would think that it would cause more heat in the engine compartment.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-18-2010, 12:13 AM   #20
pat 70/71
pat 70/71's Avatar
100 mph , We took our truck to a cruise night tonight 20 minutes one way @ 35 mph got home checked my grille and it was hot! we must remember radiators radiate heat! ( the outer grille was real warm to the touch) my truck runs great and has no problems with over heating. 100mph, if your truck runs well and the fan turns on I think your fine do not stress over this & have fun your truck will let you know when it needs service ..Pat
Old 04-18-2010, 12:36 PM   #21
100mph
Thanks Pat, it does make me feel better that I'm not alone LOL. I'll check it out more this week though but yeah, the truck seems to run great, fan turns on when it should, temp stays normal etc
Thread Tools
Display Modes
