Old 02-08-2003, 05:34 PM   #1
72MARIO
72MARIO's Avatar
17" Torque Thrust wheels Qs
Will these wheels fit without rubbing ? or will I need to get custom back spacing ? just pricing out stuff and want to see if they will work with the back spacing avaible I have a 3.5/5 drop approx. Thanks
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-08-2003, 11:07 PM   #2
big.l.a
big.l.a's Avatar
17 wheels
They will fit. I have 17X 8.5 on all 4 coners and no rubbing problems. And I have the same drop as you. I am on 60 series
but I the I should have when 4 the 50's X 275X 17
71 C10 LWB With
Edelbrock 7101& 1406 Carb
Accel HEI Blue Print
Accel 8.8 Wires
Soon to have possi &
186 Camel hump heads
Dropped 2-1/2F&4R
Dynomax Headers
Duals Flowtech Aftburners
Tonneau Cover Frm 89 F150
79 Monte C
big.l.a is offline   Reply With Quote
Old 02-08-2003, 11:30 PM   #3
Low68
Low68's Avatar
Here is my truck. It has a 3.5/5 drop. It has 17x8's in the front and 17x9.5's in the front. The front are 5 inch backspacing, and I think the rear should be four inch backspacing. I took some measurements and ordered my wheels. When I ordered them, they told me that I needed a different backspacing. I said, well they must know what they are talking about, so ok. They were wrong. I ended up buying spacers that look stupid. I think that they should be four inch in the back though. I have 255/50 tires in the front and 275/50 in the back. the back rub a little bit, but not bad. The front also rubs when the front goes way down, but it is also not that bad.
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 02-08-2003, 11:57 PM   #4
big.l.a
big.l.a's Avatar
17 wheels
She looks sweet. I don't know what the back spacing If for me
i got a deal for them off ebay for $ 500. I send pics once I find my camera........
71 C10 LWB With
Accel 8.8 Wires
Dropped 2-1/2F&4R
Dynomax Headers
79 Monte C
Old 02-09-2003, 02:09 AM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
4" in the rear and 5" up front??? Hmmmmm...... I've got 18x8's up front with 4.5" backspacing and 18x9.5" in the rear with 5.25" backspacing. My rear tires/sheels tuck nicely in the rear with the air bags dumped. I guess it all depends on how low you are going.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 02-09-2003, 02:18 AM   #6
BraveDave
I was just about to post this pic when i saw your thread. i just had 2-1/2 inch dropped spindles and 1-1/2 inch lowering springs installed. I am running 17 X 8's also with 4-inch backspace in front and 5-inch backspace in back. I, too, made the mistake of ordering 4-inch backspace all the way around and it just didn't look right in the front. There is just too much rim, so I bit the bullet and ordered two more. I am running 255-50's and 275-50's. I have no problem with clearance at all. I still intend to bring the rear down a bit. The original builder heated the coils and it sits lopsided. I ordered 3-inch lowering springs and 2-inch lowering blocks. This should drop it about 2 inches from where it is now. I hope this helps you. (GAAWWWWDDD I LOVE THIS TRUCK!!!)
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible
BraveDave is offline   Reply With Quote
Thread Tools
Display Modes
