Old 04-18-2010, 02:09 PM   #1
71GMCer
What kind of Transfer case is this?
Hey all,
Im new to the forums so here is abit about me:
I got my 1971 GMC 4x4 as my first truck and its probably the coolest vehicle in the school parking lot. (I am 16) It has an "01" stamped 350 sbc in it and after abit of research i found that the engine would usually be seen in a Camaro or Corvette back in the day. I has a few oil leaks but im slowly patching them up (Rear main seal, Oil pan and now im told its leaking from the oil pressure sending unit and distributor gasket)
Whats your guys' stories about leaks...im sure im not the only one who had to repair some leaks.
I was just curious as to what transfer case i have in it.
Im thinkin NP 205?
The truck
71GMCer is offline   Reply With Quote
Old 04-18-2010, 02:26 PM   #2
71swb4x4
71swb4x4's Avatar
Re: What kind of Transfer case is this?
Sharp truck. That looks like the back end of a NP 205 to me.
I doubt you are leaking from the distributor gasket, more then likely the oil from the oil sending unit is making it over that direction. Just start patching leaks and eventually you will get them all.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-18-2010, 02:34 PM   #3
71GMCer
alright thanks! Are Np 205s fairly good?
Old 04-18-2010, 02:34 PM   #4
mbgmike
np205
mbgmike is offline   Reply With Quote
Old 04-18-2010, 02:41 PM   #5
71swb4x4
71swb4x4's Avatar
NP 205's are one of the best transfer cases ever made.
Old 04-18-2010, 02:49 PM   #6
71GMCer
ah right on...im hoping my truck will last a long time because i absolutely love it. Its got a 4 speed standard tranny, dual glasspack exhausts (no headers, just straight pipes) and the amazing 350 sbc.
Can anyone tell me about that "01" stamp i found? And what kind of diff. would it have? LSD or an Open Diff?
Matt
Old 04-18-2010, 03:31 PM   #7
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Where was the 01 stamp? That sounds like you may have seen the numbers cast on the side of the block. Like Nickel contents or something. Your numbers that tell you what it is are on the front of the passenger head pad under the a/c if your truck has it. Also, when it was built and what block it is, will be on the back side of the engine behind the distributor. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 04-18-2010, 03:36 PM   #8
71GMCer
The 01 stamp was where the bolt holes are for the oil pan and abit farther up towards the top of the block
Old 04-18-2010, 03:42 PM   #9
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Yup, best case ever put in these trucks. Gear driven and beefy.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 04-18-2010, 03:53 PM   #10
71blksuper4x4
SWB 4x4 Collector
yeah, just about any small block could have had 01 stamped in it. You need the other numbers I was telling you about to decipher it. Mainly, the rear motor cast number which should start with a 39*******. A good 350 should end with the last three numbers 010. Trevor
TREVOR
Old 04-19-2010, 11:11 AM   #11
mbgmike
I have a free one that works if anyone wants one
Old 04-19-2010, 11:37 AM   #12
dukkie
My Spoon Is Too Big
dukkie's Avatar
Yup Yup Np 205
1972 C20, 03-14-10 Build Thread
2000 Silverado 4.8L, 11-04-13 (Currently Parting)
1999 Silverado 5.3L, 07-07-14. (Engine Donor)
2015 Ram 05-20-15 (Daily Driver)
dukkie is offline   Reply With Quote
Thread Tools
Display Modes
