Old 04-25-2010, 10:44 PM   #1
Big-Blue
Big-Blue's Avatar
Pate Swap Meet Stuff - Dallas
I don't have a spot but I will be there Saturday and can deliver any of this stuff...need it out of my garage. If anyone is interested let me know and I can meet you Saturday. Everything below is from a 1971.
Original gas tank with sending unit and in cab sending tube. Looks almost new...$75
Doors - Come with all glass and hardware but need a lot of work. $50 each or $80 for the pair
Radiator - Not sure it's an original but it didn't leak when I pulled it. She's not pretty....$75
Seat Frame - What can I say...need it out of the garage. $25
I am looking for a cab dolly and some nice inner fenders.
Jonathan
jdpkelley@yahoo.com
Big-Blue is offline   Reply With Quote
Old 04-25-2010, 10:54 PM   #2
1969C10shortbed
Re: Pate Swap Meet Stuff - Dallas
I don't want to sound noobish but would that gas tank fit a 65? I know in my 69 the gas tank has the fill tube, and the fill tab thing included on it, and it's approximately the same size. I live in El Paso, shipping would suck, but I might be able to meet half way?
1969C10shortbed is offline   Reply With Quote
Old 04-25-2010, 11:20 PM   #3
Big-Blue
Big-Blue's Avatar
A '65 is definitely a different tank. You might be able to make it work...but even halfway to El Paso is a looooooong way.
You can probably find a good one in a salvage yard in the dry air out there.
Good luck!
Old 04-26-2010, 12:14 AM   #4
Duncan and son
Jonathan, The radiator appears to be the original 4 core and has the places to hook up automatic transmission lines.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 04-26-2010, 01:01 AM   #5
1969C10shortbed
Good luck!
Thanks for the info! I think what I'll do is try to find the 67-69 tank, cut off the fuel neck with the gas cap arrangement thingamajig, and have it welded onto my 65's tank. My 65 has a brand new tank anyway
Old 04-26-2010, 10:06 PM   #6
Big-Blue
Big-Blue's Avatar
Thanks for the info! Maybe I will see you Saturday??
Old 04-26-2010, 10:26 PM   #7
bean
is that drivers side door rusted at the bottom?
bean is offline   Reply With Quote
Old 04-27-2010, 10:03 PM   #8
Big-Blue
Big-Blue's Avatar
Yeah, I would recommend putting a new bottom on both of them.
Old 04-27-2010, 10:35 PM   #9
reds_racing
I bought a set of buckets off ebay and the drivers seat brackets didn't have the slide lever or mechanism. I will reasearch to see if your bench seat lever and catches will work, if so, I will buy it Saturday.
reds_racing is offline   Reply With Quote
Old 04-28-2010, 01:59 PM   #10
Big-Blue
Big-Blue's Avatar
Let me know ahead of time as I am not bringing anything that isn't sold prior.
The rails have a little bit of surface rust but should clean up pretty nicely.
Old 04-30-2010, 03:05 PM   #11
67-1sttimer
67-1sttimer's Avatar
Hello, interested in the Radiator. I have a 67 1/2t swb w/ I6 250 also standard 3 speed, will it work in my ride? Does have any leaks or defects that require repair? I need one that ready go in and work only. Thanks, Chris.
67-1sttimer is offline   Reply With Quote
Old 05-01-2010, 04:21 PM   #12
Big-Blue
Big-Blue's Avatar
Sorry for the delay in responding. I am not sure if it will work on your ride. You many need to do a little research. It was working when I pulled it but I only drove it around the block. I never really heated her up. It did seem to hold water though.
Thread Tools
Display Modes
