Old 04-26-2010, 06:51 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Question HEI Problem
Okay I bought a '72 c/10 and found out something interesting with it.
It has a HEI dizzy but wasn't wired correctly.
The only way to turn it off (key doesn't do it) is to reach down and unplug a wire from the fuse block.
How can I correctly wire this so when the key is off the engine dies?
Thanks!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 04-26-2010, 07:08 PM   #2
LONGHAIR
Re: HEI Problem
Changing the place where that wire is connected will do it. It needs to be a "switched" source....something that goes on/off with the key.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-26-2010, 07:16 PM   #3
C20-67_N_MO
Re: HEI Problem
Okay that sounds simple enough.
So just look for a "switch" connection then.
Cool, Thanks!
Old 04-26-2010, 08:19 PM   #4
Sammy
Re: HEI Problem
There is a switched plug on the fuse box you can use. Go to FAQ and look at the pic of the fuse box, your fuse box maybe hard to read to find the correct spot.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-26-2010, 08:22 PM   #5
C20-67_N_MO
Unhappy Re: HEI Problem
Yeah the problem is it looks like SEVERAL hot wires are feed into this one plug on the fuse block. Someone really did a hack job on the electrical system of this poor truck.
Old 04-26-2010, 08:34 PM   #6
Blue72slab
Re: HEI Problem
You can also run it off the back of your ignition switch. I would recommend #12 primary wire to insure a good solid 12-14V to the distributor.
Blue72slab is offline   Reply With Quote
Old 04-30-2010, 01:36 PM   #7
C20-67_N_MO
Re: HEI Problem
Okay now I got another odd problem.
If I hook up the wire going to the dizzy to a switched source on my fuse block the engine will not start unless I release the key (which stops turning it over) and then it will start. (Sometimes).
But if I hook it up to power all the time it starts right up.
Is that switch connection maybe not a full 12volts?
Help!
Old 04-30-2010, 04:17 PM   #8
LONGHAIR
Re: HEI Problem
You really need to find the right place in the fuse block. The place you have now is only "hot" in the "run" position. It need to be "hot" while cranking too.
Some things go "off" while the engine is cranking (like the radio) to save it all for the cranking/starting process. Obviously, the distributor cannot be one of those.
Old 04-30-2010, 06:26 PM   #9
Wrenchbender Ret
Re: HEI Problem
The best way is like Slab says. Tie in to the pink wire on the back of the ign. switch with 12 gauge wire. I peel off a little insulation & solder the wire to it. This way you have no voltage drop & the wire can't come loose & shut you down.
Wrenchbender Ret is offline   Reply With Quote
Old 04-30-2010, 06:40 PM   #10
C20-67_N_MO
Re: HEI Problem
Okay, will try to tackle this job on the weekend.
Thanks guys.
Old 04-30-2010, 07:15 PM   #11
fixit-p
fixit-p's Avatar
Re: HEI Problem
The port (ign unfused) on the fuse block comes from the pink ignition wire and if it's not getting power in the start position then your ignition switch is bad or the PO modified it.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 04-30-2010, 09:53 PM   #12
C20-67_N_MO
Re: HEI Problem
Thanks fixit-p.
Yeah the PO did a LOT of damage to the entire wiring system of this poor truck. Everything from direct wiring of the headlights to other fire hazards.
Your picture should help a lot.
Appreciate it.
Scott.
Old 05-01-2010, 09:00 PM   #13
RustyDan
RustyDan's Avatar
Re: HEI Problem
Hey FIXITp...A little more rust and the pic with the camper could be my rig the day I got it from Pop. Still trying to download from my cam. Nice truck/camper. got more pics? info?
RustyDan is offline   Reply With Quote
Old 05-01-2010, 09:04 PM   #14
C20-67_N_MO
Re: HEI Problem
Tested connection at IGN and it is dead. On either side of the fuse is dead as well. Very strange deal. Like I said the PO did a LOT of hack job to this electrial system.
Hate to do it but might just have to take it to a shop next week.
Old 05-01-2010, 09:52 PM   #15
jamie72
jamie72's Avatar
Re: HEI Problem
instead of taking it to the shop i would just used that $$ and buy a new wire harness...
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-01-2010, 11:14 PM   #16
C20-67_N_MO
Lightbulb Re: HEI Problem
Oh I have one!
And it's not going in this '72, but rather saving it for when I use the parts from this truck on my '67.
I know of a guy that won't charge me too much or we trade services so it will not cost me too much any way.
Old 05-01-2010, 11:15 PM   #17
fixit-p
fixit-p's Avatar
Re: HEI Problem
Thanks, no pics but I ditched the camper and it did an awesome job of preseving the bed floor and interior.
It may just be a bad ignition switch, if you can disconect the plug on the back of the iggy switch you could use a jumper wire to connect the red and pink wires if power is restored to the ign port then you know the ignition switch is bad if it didn't restore power look for a break or suspect connections on the pink wire.
Old 05-01-2010, 11:31 PM   #18
RustyDan
RustyDan's Avatar
Re: HEI Problem
Yea...My camper did a fine job saving the lumber in my truck as well.
Pop said he only had it off the truck 2 times in 33 years. LOL
"Do not follow where the path may lead.
Go instead where there is no path and leave a trail."
"SEMPER FI"
Never retired-Always a Marine
'72 C10 Longhorn-very daily
'86 C10 Van (mothballed)
previous; '65 C10 shorty
& bunches of M/C's
Old 05-03-2010, 06:58 PM   #19
RussGapp
Re: HEI Problem
The reason That your truck won't start unless you release the key, is that the wire to the original coil on a 67 was a resistor wire, which prevented the the points from getting a full 12 volts and dying an untimely death. When the engine is cranked over the coil is fed about 9 volts. when you release the key to run, you get 12 volts and the engine will start, sometimes. You need to replace that wire from the firewall plug to the HEI with a #10 or #12 wire. This will allow 12 volts to the HEI when cranking.
RussGapp is offline   Reply With Quote
Thread Tools
Display Modes
