Old 04-27-2010, 09:53 AM   #1
kernalklink
kernalklink's Avatar
max tire size on a stock 4x4
one of my tires finally gave out, the sidewall split open because they had sat for about 10 years tread was like new but they were very dry rotted and cracked - im surprised they lasted as long as they did. i got about 50 miles out of them.
currently it has 30x9.5x15 and they look small on the truck
whats the largest tire i can go with on the front with stock suspension
i dont have anything for a box on the rear right now and will probably get a flatbed for it so im not worried about the rear rubbing
1967 K20 'the white truck'
sm420/Rockwell t221
Dana 44 front w/ Dana Spicer 1/4 turn lockouts
Eaton Ho52 rear
"holy **** this thing is a tank!"
As soon as your born you start dying so you might as well have a good time!
kernalklink is offline   Reply With Quote
Old 04-27-2010, 12:11 PM   #2
CG
BlahBlahBlah
Re: max tire size on a stock 4x4
Id have to say 33x12.5, Thats what I have on my 4x4 with no lift
Old 04-27-2010, 12:17 PM   #3
kernalklink
do you have any pics? 33x12.5 would be really cool
sm420/Rockwell t221
Eaton Ho52 rear
Old 04-27-2010, 01:22 PM   #4
CG
BlahBlahBlah
Its a 3/4 ton but fitment is the same for a 1/2 ton...I had 33's on my 1/2 before I put a small lift on it.
Old 04-27-2010, 01:31 PM   #5
kernalklink
very nice truck! - mine is also a 3/4 ton - those are even the tires i am looking at i could not have had a better example thanks so much!
sm420/Rockwell t221
Eaton Ho52 rear
Old 04-27-2010, 01:57 PM   #6
CG
BlahBlahBlah
She's pretty in pictures, not so much in real life lol. Glad it helps.
Old 04-27-2010, 02:00 PM   #7
dauntless_powered
dauntless_powered's Avatar
CG,
that pic is with no lift? What are they 33X12.5's?
Erik
1967 K10 SWB Big Window - Bone Stock
1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage)
dauntless_powered is offline   Reply With Quote
Old 04-27-2010, 02:12 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Wheel width and offset will matter with 33/12.50 and stock suspension... get it wrong and it will rub. Years ago I trimmed the leading edge of the front fenders b/c 11.00-15 TrueTracs were rubbing.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-27-2010, 03:26 PM   #9
kernalklink
i thought that looked like the most likely place it would rub - lucky mine is mostly rusted gone on the driver side - i can cut the passenger side to match and shouldnt have issue -
now all i need is about $800 to buy some tires
sm420/Rockwell t221
Eaton Ho52 rear
Old 04-27-2010, 04:18 PM   #10
dauntless_powered
So, some 32X11.5's should fit nicely then on my 67 swb K10
Erik
Old 04-27-2010, 08:02 PM   #11
iwanta70
iwanta70's Avatar
If you're curious what a lift would give for clearance, here's a 2" spring lift on the front end only. The back still has a 1 1/2" block in it, haven't gotten the 2" springs on yet.
EDIT: forgot to say the tires are 33 X 12.5
'71 K10, ps, pb, a/c, tilt, tach and LOTS of rust
iwanta70 is offline   Reply With Quote
Old 04-27-2010, 08:29 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^ That's the exact stance my K20 has, with 2 1/2" front springs and rear add-a-leafs, and 33/12.50-16.5 tires on 9.75" wheels.
- Mike -
RIP El Jay
Old 04-28-2010, 01:09 AM   #13
CG
BlahBlahBlah
Yeah no lift and 33 12.5's. Bought this truck from the original owner, its all stock underneath...except the back has a set of those helper leafs. I believe those only come into play with an extra heavy load though.
My old, now oldirons, K10 had the same size tires, 33 12.5 with the same 2.5 inch lift as iwanta70 and Stockers. I think that's the perfect size lift if you are going to have one in a 4x4 that you actually use as a truck. Someday I hope to do that to the K20.
Not that it matters in this thread, but I had a 72 C20 that was actually lowered just a smidgen. It had 33 12.5 tires too...boy did they fill up the wheel well...lol.
Old 04-28-2010, 01:14 AM   #14
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I was just talking about this last night to a friend of mine, and I was saying that 31's would look nice, and probably be the biggest. Now I'm going to have to retract what I told him and show him that the right set of 33's will look even better.
CG I totally dig the way that truck looks; everything about it. If I do put a lift on mine it would only be the 2" like you said. I think any higher would just make it hard for a DD.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 04-28-2010, 01:15 AM   #15
nickp51chevy
double post.... my bad!
Had;
Old 04-28-2010, 08:20 AM   #16
msgross
msgross's Avatar
wheel width and backspacing are the key though, as stated.
I have 33x10.5 in this pic... I got a heck of a deal but I was planning on 32x11.5 or 33x12.5
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-28-2010, 08:27 AM   #17
msgross
msgross's Avatar
these are the same with a 1.5" lift (add-a-leaf) and a 2WD rear axle (1.5" wider)
The Garage:
Old 08-23-2016, 06:33 PM   #18
Timmerduder
Timmerduder's Avatar
255 85 16 are 33" tall but only 9" wide... much better for snow
Tim in Oregon
http://timmerduder.com/72chevy.htm
Timmerduder is offline   Reply With Quote
Old 08-23-2016, 06:35 PM   #19
Timmerduder
That does have three quarter ton inverted springs with an add a leaf on the front and 2 inch block on the back, half ton 72.
Tim in Oregon
Thread Tools
Display Modes
