Old 04-28-2010, 05:08 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
diff oil
I tried the search button but nothing came up, so I thought I'd just ask. what oil is recommended for your differential? mine is an open diff with 373 gears, and I will be doing a good bit of heavy towing this summer if it makes a difference. thanks
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 04-28-2010, 05:30 PM   #2
bean
Re: diff oil
I literally just finished changing the oil in my 72. A multigrade, 80-140, will take care of it. I used a SWEPCO brand that is fantastic has moly in it as well.
bean is offline   Reply With Quote
Old 04-28-2010, 05:46 PM   #3
cdowns
cdowns's Avatar
Re: diff oil
synthetic is bestest
i use royal purple or mbil one in everything i own//engine trannys and rears
Old 04-28-2010, 05:49 PM   #4
Wrenchbender Ret
Re: diff oil
I agree with Bean. Any good gear lube with a GL5 rating will work fine. Some like the synthetic types but I don't think the added expense is nessesary & I like natural stuff.
Wrenchbender Ret is offline   Reply With Quote
Old 04-28-2010, 07:32 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: diff oil
You'll get opinions all over the map... No doubt dino is perfectly acceptable (I ran it for many years without issues), but I now prefer synthetic 75W-90 (Mobil-1, and I have also used Redline). Valid or not, my perception is better flow, resulting in lower rolling resistance when cold, and better lubrication if very hot or at high pressures.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-28-2010, 07:40 PM   #6
LONGHAIR
Re: diff oil
I am definately a believer in synthetics. They run much cooler, which is far better for everything inside the housing.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-28-2010, 07:41 PM   #7
mclairmo
Re: diff oil
I don't like synthetic. It's unnecessary, costs too much and can lead to leaks. The synthetic has a bad habit of leaking out when there was no leak before.
mclairmo is offline   Reply With Quote
Old 04-28-2010, 07:46 PM   #8
capev86
Re: diff oil
i have royal purple manual trans fluid in the saginaw (3onthetree) in my 72 burb 3/4 ton 2wd. going to put royal purple 75w-90 in the HO52 rear when i get the 4.10 swap done in the next couple weeks. fresh oil is better than nothing, but people don't realize how much heat/wear rear ends are subjected to and synthetic makes sense. mobil 1 and supertech (walmart brand) have cheaper synthetic gear oils but i'll be working my truck hard with trailer towing. it will be getting royal purple engine oil when i get the 406sbc swapped in but right now it has mobil 1 high mileage 10w-30 in the stock 74,000 original mile 307.
capev86 is offline   Reply With Quote
Old 04-29-2010, 12:51 AM   #9
1968CHEVYC10
Re: diff oil
thanks for the input yall, how much oil will go into these things?
Old 04-29-2010, 04:52 AM   #10
cdowns
cdowns's Avatar
Re: diff oil
a bit less than 2quarts for a rearend
Thread Tools
Display Modes
