Old 04-29-2010, 11:32 AM   #1
bebesjoys
power steering pump?
Hi
I am looking for some help. On a 69 k10 307ci were do you mount the p/s pump? It hits the alt bracket if mounted under it on drivers side. Can the alt be moved, how was it mounted from the factory? I removed the air pump from the otherside.
Thanks for the help
bebesjoys is offline   Reply With Quote
Old 04-29-2010, 02:31 PM   #2
john
member #16
john's Avatar
Re: power steering pump?
Heres a pic i saved that was posted here. Maybe it will help.
john is offline   Reply With Quote
Old 04-29-2010, 03:20 PM   #3
El Jay
Gone to greener pastures
These pictures aren't very clear, but we mounted the P/S on the left side of the engine & moved the alternator to the right side by using a later style mount from a '76.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-29-2010, 03:28 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if the pump hits the alt, then you have the wrong, later style pump brackets.
Old 04-29-2010, 03:56 PM   #5
rsavage
rsavage's Avatar
The correct pump bracket bolts to the 2 holes in the lower front driver's side of the block and the first motor mount to block bolt as in the first and last photo.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-29-2010, 05:32 PM   #6
mclairmo
Yeah, in my 68 C10 I have the car style power steering brackets that mount to the water pump and driver's side head instead of the block and motor mount and they put the power steering pump up much higher. You need the correct truck style power steering pump brackets like in the above photo that puts the pump much lower. You can usually find them on Ebay for about $30-$40. Or you can move the alt to the passenger side using 69 and later car brackets or aftermarket brackets. I'm using the Skip White billet alternator brackets to do just that.
mclairmo is offline   Reply With Quote
Old 04-29-2010, 07:31 PM   #7
bebesjoys
thanks great feedback
Thread Tools
Display Modes
