Old 05-03-2010, 11:23 PM   #1
raverider
Smile lq4 block what heads?
I am putting an lq4 into my 67 swb, and im curious as to what heads i will be able to put on it. I have the iron heads now and want aluminum ones. Will the l92's fit if i put a bigger cam in and no pistons w/reliefs. I have searched on line but found conflicting views on pistons w/ reliefs. Would i be better off getting a set of 317's? Anyone else know of any other heads/cam i can put in it to spice it up a bit. Thanx
raverider is offline   Reply With Quote
Old 05-03-2010, 11:37 PM   #2
68 short step
Re: lq4 block what heads?
the l92 heads will fit it, you'll need a compatible intake tho...also the 317s are a good choice too....
68 short step is offline   Reply With Quote
Old 05-03-2010, 11:41 PM   #3
'72customdeluxe
his current heads are identical to 317's besides material. Both will run fine on 87 with stock compression. So unless they are milled (then just go for 243's) stay with stock
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 05-03-2010, 11:42 PM   #4
raverider
the iron and aluminum 317's flow the same? as far as l92's i cant use my stock intake? l76?
Old 05-03-2010, 11:45 PM   #5
'72customdeluxe
1. correct, same as a 317 but iron
2. nope, your heads are cathedral port, those heads are rectangle port
Old 05-03-2010, 11:48 PM   #6
raverider
understood. are there any other heads that i can run without having to change the intake and wont have to have reliefs, that flow better? And dont cost a bajillion dollars haha
Old 05-03-2010, 11:54 PM   #7
'72customdeluxe
you could mill your heads or use 243's (ls2 or ls6, same ports as yours) to make more compression.
Old 05-04-2010, 12:01 AM   #8
raverider
with the 243's would i benefit from running a different cam? if so waht would you recommend?
Old 05-04-2010, 06:54 AM   #9
matchstick
matchstick's Avatar
If you milled your heads they would be the same as a 243. The only difference is the combustion chamber cc. I've got several sets of each if you are interested in just changing over to aluminum. If it were me, unless you were wanting to race it or go wild with it and make 450 + rwhp , I'd just do a cam swap and leave the heads on it you've got.
matchstick is offline   Reply With Quote
Old 05-04-2010, 10:40 AM   #10
raverider
well of course i would love 450 plus hahaha
Old 05-04-2010, 11:53 AM   #11
matchstick
matchstick's Avatar
Then order you a set of ported heads and a camshaft from Texas Speed or ant other LS warehouse and you should be good to go. $2k or less should cover everything you need for 450.
Thread Tools
Display Modes
