05-04-2010, 09:22 AM | #1 |
How do I remove this?
Ok, how do I get this pieces off. It's the u shaped piece that the steering box connects to on the axle in the upper right of the picture. There are 3 bolts holding it on. I have removed them, but it still won't come off. Is there a trick to it, or does it just not come off?
Here is a picture:
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 Last edited by JimmyFloyd; 05-04-2010 at 09:23 AM. |
05-04-2010, 09:40 AM | #2 |
PROJECT 7DEUCE
Re: How do I remove this?
You may wanna start by getting some good penetrating oil on there then remove the 3 bolts on top. Iirc the washers are tapered and it makes the whole deal a pita..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-04-2010, 09:41 AM | #3 |
Clean it off soak it with blaster Big *@#$%# hammer lots of heat and just beat on it till it brakes loose. It's not easy you will use lots of bad Word before it's off
Good luck
C/10 John N.J. |
05-04-2010, 09:45 AM | #4 |
Ok, I have the nuts off already, and the steering box, is removed since the picture was taken, just couldn't get it off. I tries a small hammer, but sounds like I need to get the BFH out and give it a whack.
Next question, is it worth keeping if I am not keeping the axle itself? Or am I making more work? And lastly, how to I remove the Center Link that goes horizontally across that picture? Do I need any special tools?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
05-04-2010, 09:51 AM | #5 |
You'll need a fork thats made just for the joint it just slides between the two parts one god hit it should pop off ass for the c link keep hitting with a bigger hammer it will come off
C/10 John N.J. |
05-04-2010, 09:52 AM | #6 |
ok, I have the fork I used to remove the steering box still, so that should work for the ends of the Center Link, correct?
05-04-2010, 09:55 AM | #7 |
if you don't need the axle let stay right where it is
C/10 John N.J. |
05-04-2010, 09:55 AM | #8 |
Yes
C/10 John N.J. |
05-04-2010, 09:57 AM | #9 |
ok, That makes things easier. i just need the Center Link cause there is a local guy who wants it, but the rest I can live without. Was just going to remove it so I could sell it, but if it is too much trouble, then I am not going to bother.
05-04-2010, 09:59 AM | #10 |
Is there anything else there that I should keep?
Thread Tools | |
Display Modes | |
