Old 05-07-2010, 06:01 AM   #1
cheyenne402
Lowering 1986 longbox
Hello,
I want to lower my longbox, but I am unsure what to use in the rear. I bought shackles awhile ago, but notice now that that would probably require hacking the bed rails. Any suggestions on where to buy a good kit to lower the back 4-5" and the front 2.5-3" ? (price does matter)
cheyenne402 is offline   Reply With Quote
Old 05-07-2010, 06:26 AM   #2
bitchin85
bitchin85's Avatar
Re: Lowering 1986 longbox
if your drop shackles are big then you probably will have to cut into the x-members.. i would do an axle flip to the top of the leafs. the kit is pretty cheap and pretty easy to do. the amount of drop u get depends on how many leafs you have in the rear. it will give you 5-6ish inches of drop. and i dont know for sure but i think you have to do a mild c-notch. its easy with a kit or u could make your own pretty easily
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 05-07-2010, 08:25 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
the rear flip kit
http://www.summitracing.com/parts/DJM-FK1024-5/
font drop coils
http://www.summitracing.com/parts/SUM-G726/
drop shocks
http://www.summitracing.com/parts/SUM-G7727/
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-07-2010, 11:09 AM   #4
MobSled
MobSled's Avatar
Cheapest way....flipkit from summitracing.com, don't think your require a cnotch with only 5in drop. Yank out the front coils, if you don't feel like spending 100 bucks on drop coils, cut a coil and half off your oem springs. Coil and half will give you a 3inch drop.
Good luck.
MobSled is offline   Reply With Quote
Old 05-07-2010, 04:17 PM   #5
cheyenne402
Does the Summit flip kit come with c-notch destructions? I already have drop coils from Summit for the front. I also have the drop shocks.
Old 05-07-2010, 04:49 PM   #6
81ratrodc10
house of chevy's
81ratrodc10's Avatar
i would recomend a c notch going to do one on my axel flip it hits the frame from time to time
81ratrodc10 is offline   Reply With Quote
Old 05-08-2010, 02:19 AM   #7
moneyeater
moneyeater's Avatar
I´ve got a flipkit on my longbox without the c-notch and modified the original bumpstops and i´m fine! when i put weight in the bed the axle lays on the soft rubberbumpers and doesn´t ride bad! The stance is good too!
Name:  IMGP0620 [640x480].JPG
Name:  IMGP0619 [640x480].JPG
Name:  IMGP0617 [640x480].JPG
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 05-08-2010, 01:33 PM   #8
cheyenne402
Moneyeater,
How much is your truck lowered front and rear?
Old 05-09-2010, 10:04 AM   #9
moneyeater
moneyeater's Avatar
It´s lowered 4.5/6 i think and i tried it with 2 leafes removed but that was to much so i put them back in and i´m fine!
The ride is sporty but not harsh.When i hit a hole or bump in the road to fast the front tires rub the wheelwells a bit but thats ok since they stick out a little!
Volker
Come have a look!
Old 05-09-2010, 11:21 AM   #10
bigdnew
Never Satisfied
bigdnew's Avatar
check out norcal ss in the vendor section he will meet or beat anyone's price. he is who i picked up my 5" front and 5" rear drop. great gyuy to work with. check out my build thread, i have the rear end back together with no c-notch and have plenty of room. should have the front back together this week. went with 3" drop spindles and 2" drop springs.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Thread Tools
Display Modes
