05-09-2010, 09:37 AM | #1 |
Door lock troubles
My driver's side door will not lock and I was hoping to get some help. When I try to push down the knob to lock the door, it won't budge. If I open the door and lift the release lever at the same time that I push the button, it will go down. But when I close the door it pops back up.
Any ideas? |
05-09-2010, 09:56 AM | #2 |
The Older Generation
Re: Door lock troubles
The door has to be closed and you have to lock it with the key. You can't lock the doors on our trucks by pushing the button down and closing the door. If it won't lock with the key then the door is probably too tight & needs to be adjusted. LockDoc
05-09-2010, 10:01 AM | #3 |
Thanks for the insight. This is my first truck like this. Just got it yesterday.
It won't lock still with door closed. Should I play with the adjustments on the lock plate in the door sill? |
05-09-2010, 10:38 AM | #4 |
Enjoy the new truck
1972 Custom/10 Deluxe SWB 4wd " The Green Gobbler" |
05-09-2010, 06:49 PM | #5 |
I had to take mine apart and clean and lube. Be careful not to lose any of the clips.
I'm not as good as I once was, But I'm as good once as I ever was. |
05-09-2010, 10:53 PM | #6 | |
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-26-2022 at 12:59 PM. |
05-09-2010, 10:56 PM | #7 |
What shape our your window and channel seals in? I had a piece of rubber fall right in the path of the mechanism and I couldn't lock my door. Pulled the piece out and she worked. I replace all the seals.
Thread Tools | |
Display Modes | |
