Old 05-09-2010, 11:01 AM   #1
67k/20
67k/20's Avatar
power steering help
hi all, im new here so not sure if this is in the rite spot. i have a 67 k/20 with manual steering and i wanta change it to power. i found a complete power steering set up off a 72 2wd truck. my question is will that box work on my frame? and if not can i use a box off any of the 73-87 trucks?
67k/20 is offline   Reply With Quote
Old 05-09-2010, 01:02 PM   #2
rsavage
rsavage's Avatar
Re: power steering help
There is a difference in the PS boxes between 2wd and 4wd. They used the Saginaw boxes for a lot of years but someone else will have to tell you the range and when they switched to metric fittings. I believe that you will have to dimple your 67 frame for the box to fit up against the frame correctly. Lots of power steering info on past threads if you want to search.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Thread Tools
Display Modes
