05-14-2010, 12:37 AM | #1 |
Have pity on a newbie
I've been around trucks and cars alot but this is my first true GM (besides my wife's Blazer and my old Grand Am yuck). I have a 72 GMC 2wd short bed. From what I can gather it was a big block truck. Did 402 trucks come with 4 speeds or were they all th400s? Mine has the low hump so I'm guessing it was an auto. Anybody have any pics handy of what the cross members should look like? It now has a 350/350 in it. It was green and is now blue with black interior. They put a newer tilt column in it, cut the radio hole, and filled the original ignition and lighter I'm also 95% sure it has a 73 up 12 bolt under it too. The reason I think this is the driver's side shock lower shock mount has been cut off and rewelded on and they're directly in line with the frame instead of offset. Thanks in advance for the help. Also can anyone tell me what year this grille is? I'm sure it's aftermarket.
05-14-2010, 12:50 AM | #2 |
Roadtrip!
Re: Have pity on a newbie
I think the front end looks like 69-70. If the truck was a th400, or 4 speed, it should have a high hump in it. Welcome...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
05-14-2010, 12:59 AM | #3 |
Hey thanks for the reply. Yeah I remember reading that somewhere now. Here is why I think it was a big block truck:
http://www.vinwiz.com/1972-1980gmtru...=TCE142B507513 |
05-14-2010, 08:32 AM | #4 |
G.M. NEVER PUT A T-350 BEHIND A BIG BLOCK IN THESE. THE ONLY CHOICES WERE A T-400 OR A 4 SPEED, BOTH OF WITCH CAME WITH A HIGH HUMP. IN 38 YEARS YOUR TRUCK COULD HAVE HAD ALOT OF DIFFERENT OWNERS, THAT REPLACED ALOT OF DIFFERENT THINGS, LIKE A CAB, & IT'S NOT UNUSUAL FOR SOMEONE TO REPLACE THE CAB & RETAIN THE VIN. PLATE & GLOVE BOX DOOR. WELCOME TO THE WORLD OF OLD TRUCKS FROM SOMERSET KY. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-14-2010, 10:06 AM | #5 | |
Roadtrip!
05-14-2010, 10:35 AM | #6 |
Thanks for the help guys. I didn't think this is the factory trans. I ran the #'s on the engine and I know its not factory. Maybe mine was a 3 speed truck. It has had the brake pedal cut and a wide pedal welded on. And the column being changed makes me wonder too. I don't think the tag is still on the glove box lid. I'll have to look and make sure its not just painted over. Any other things to check to see if it had a 3 speed? Is the vin # on the frame? Clutch brackets maybe?
05-14-2010, 12:16 PM | #7 |
Redefining LowBudget
check your glove box build sheet......
that looks like a 69 GMC grill
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
05-14-2010, 04:02 PM | #8 |
If it's not there is there any way to get the info? Maybe from a dealer?
05-14-2010, 04:07 PM | #9 |
Okay its there but it's covered in about 3 layers of cheap paint Any suggestions on how to remove it without removing they info I so desire?
05-14-2010, 04:13 PM | #10 | |
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
05-14-2010, 04:52 PM | #11 |
Well I got it cleaned up enough to see the codes. Here's what I got, but it makes no mention of the engine or trans.
model=CE15734 A11 Tinted Glass B85 Belt Molding B93 Door Edge Guards F59 Front Stabilizer G70 R Susp-Leaf Spring G80 Positraction Axle J70 Brake Booster Equip P01 Full Wheel Covers U63 AM Push Button Radio V43 Rear Step Bumper Z53 Ammeter-Oil Gauge Z84 Cheyenne Equipment 466 White & Dark Olive |
05-14-2010, 04:52 PM | #12 |
"Hooked on Quack"
I like the color of it........bout al I can add but nice score.
Semper Fi, Kevin USMC |
05-14-2010, 05:24 PM | #13 |
Anybody know how to find out what engine/trans mine came with?
05-14-2010, 05:32 PM | #14 |
Being it's not listed on the SPID, and it does have the "E" code, probably a 307 v8, also likely it was a 3 speed on the column, since there's no auto tranny listed. Nice looking truck though, have fun with it!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
05-14-2010, 05:43 PM | #15 |
What does the z84, b85, and b93 consist of?
05-14-2010, 06:26 PM | #16 |
Gone to greener pastures
The info I have available, which is for Chevys, says:
Z84=CST pkg. B85=Body side molding, upper B93=Door edge guards Just for fun, I checked the SPID on my GMC with the Chevy options list & the options (that I have) were the same as Chevy.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
05-14-2010, 06:40 PM | #17 |
Nice truck.
05-14-2010, 08:33 PM | #18 |
Thanks for the compliments. I wish it was all stock but I'm sure everybody does. I was wondering though what all the Cheyenne package changes on the truck.
05-15-2010, 10:59 AM | #19 | |
Cheyenne super= sierra grande
05-15-2010, 11:28 AM | #20 |
nice truck welcome to the board from indiana..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
05-15-2010, 12:43 PM | #21 |
So should mine have had the woodgrain? It says it was dark olive and white. Would that be a white top then green, then white, and then green on the bottom, or would it just be green with a white stripe around the middle?
05-15-2010, 05:16 PM | #22 |
how did you get the paint off the build sheet mine is painted over too
05-15-2010, 09:57 PM | #23 |
It sounds like it was a Sierra originally. So it would probably have woodgrain on the door panels but not on the glovebox or Guage cluster. The face of the cluster on a GMC Sierra would be color coded to match the color od the interior. If your SPID list the color as 466 white/dark olive it would be olive with a white top only, other wise it would read something like white/dark olive/white/dark olive sort of like the one below that shows a 4-way paint.
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-15-2010, 11:41 PM | #24 |
05-15-2010, 11:50 PM | #25 | |
Thread Tools | |
Display Modes | |
