Old 05-14-2010, 07:03 PM   #1
crushermechanic
crushermechanic's Avatar
what is this?
can any body help me identify what this isand teel me what it does. i am starting to build my wire harness and dont know if i need to keep it. it is on the firewall on the drivers side behind the hood hinge.
crushermechanic is offline   Reply With Quote
Old 05-14-2010, 07:19 PM   #2
mclairmo
Re: what is this?
Relays of some sort?
mclairmo is offline   Reply With Quote
Old 05-14-2010, 07:20 PM   #3
Richard H.
Spanked once
Richard H.'s Avatar
Re: what is this?
I do believe that is for an emission thing that you probably don't need. No idea how it worked
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 05-15-2010, 10:26 AM   #4
crushermechanic
Re: what is this?
any more ideas?
Old 05-17-2010, 12:06 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: what is this?
smog equipment. ESC I think is what it was called. You can remove it, and the wires, and the little gizmo it controls in the vac mile going to the dist.
Old 05-17-2010, 05:48 PM   #6
pickupman
pickupman's Avatar
Re: what is this?
longhorn is right. I have only seen them on 71
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 05-17-2010, 09:11 PM   #7
crushermechanic
Re: what is this?
cool thanks i dont have any smog equipment anyway. i will just do away with it.
Old 05-17-2010, 09:59 PM   #8
ERASER5
ERASER5's Avatar
Re: what is this?
Transmission Spark Control -- TSC. The vacuum advance was disabled until the coolant temp is above 32 degrees, and the transmission is in high gear.
This system was on my 70 GMC. I thought that the TSC started in 69 but I have not been able to verify that.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-17-2010, 10:29 PM   #9
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: what is this?
X2 at lease this is what I was told , I took it out didn't need it My 72 had it.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Thread Tools
Display Modes
