Old 05-15-2010, 07:45 PM   #1
zed71
Show your box!
Boxed frames that is...
I am building a tow hauler, and want to be able to tow and haul 10000lbs.
I am doing a frame off restoration. Putting on 2" Tuff Country spring lift.
I'd sure like to box the frame, but would like to see what some people have done here.
Thanks guys.
Currently restoring a '72 LWB k1500.
zed71 is offline   Reply With Quote
Old 05-23-2010, 12:03 PM   #2
bikes&bowties
bikes&bowties's Avatar
Re: Show your box!
This wont help much but its simple warnings...
Boxed frames tend to hold moisture and we all know how well moisture and steel get along... also lift springs are going to opposite direction for towing... what are you doing for brakes?
bikes&bowties is offline   Reply With Quote
Old 05-23-2010, 01:54 PM   #3
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: Show your box!
Originally Posted by zed71 View Post
I am building a tow hauler, and want to be able to tow and haul 10000lbs.Thanks guys.
10,000 lbs is in 1 ton range,Springs and frame are not the only considerations for towing capacity. Brakes should play a major part.Tire capacity is another.
powerdriver 1958 is offline   Reply With Quote
Old 05-23-2010, 02:03 PM   #4
Goldfinger
Goldfinger's Avatar
Re: Show your box!
Major issues with boxed frames that rust. My 85 easily tows 5 tons stock. Reinforcement would be fine. hardware is also harder to install/remove. lift springs take away from towing capacity. For a super strong Bumper that is rated at 6 tons Google Hercules bumpers in Pelham Georgia if they are still around. also for gooseneck/fifth wheel i found that you will never go wrong with a rail system reinforced by a 3/4 inch plate welded across the top of the frame right above axles.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Thread Tools
Display Modes
