Old 05-17-2010, 01:34 PM   #1
DirtyDrew
DirtyDrew's Avatar
has anybody bought boyds gas tank?
i have a 66 chevy and i want to buy a boyds gas tank for it. now they offer the tank for a 67-73 and i know the dimensions seem correct but i want to find somebody else who has bought one already. thanks a lot!
DirtyDrew is offline   Reply With Quote
Old 05-17-2010, 01:38 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: has anybody bought boyds gas tank?
call David Boyd, PM him or email. He will fix you up, the 63-72 tanks are pretty much all the same except you can chose where to have the fill at. The fram rails are identical.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-17-2010, 02:15 PM   #3
bosephus
bosephus's Avatar
Double check your dimensions because the panhard bar brace doesn't sit in the frame @ 90 degrees(one side doesnt have the clearance as the other).That being said,I bought one of Dave's tanks (for a 61) and I am very happy with it!He'll build any dimensions you need.
bosephus is offline   Reply With Quote
Old 05-17-2010, 02:21 PM   #4
DirtyDrew
DirtyDrew's Avatar
i already talked to hime and he said the tanks are a lil different and hes not exactly sure how. so before i place my order im just trying to double check.
Old 05-18-2010, 12:51 AM   #5
Captainfab
60-66 Nut
The frames are the same from '63-'72. So a tank intended for a '67-'72 will fit the same in a '63-'66. This is why the '69-'72 Blazer tanks will fit the '63-'72 trucks. I have read in his for sale thread about the crossmember issue with the shortbed trucks. Since he is now aware of the issue, I would think it has been taken care of.
Old 05-18-2010, 10:24 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
We have found that some of the shortbeds have the rear crossmember in a slightly forward position, by one inch. Not sure if this was a plant differance issue or MFG issue, measure twice, then call.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
boyds welding gas tank
Thread Tools
Display Modes
