Old 05-19-2010, 10:17 AM   #1
7ft stew
reverse and 1st but no 2nd and 3rd
76 2wd blazer with pontiac 350 and I think 350 tranny,has the notch in the pan corner. Is there any sort of vaccum line that might have came off that would make not shift into 2nd or 3rd? I've read plenty of posts that say reverse and 1st are the first ones that go out. Any info is appreciated
7ft stew is offline   Reply With Quote
Old 05-19-2010, 10:28 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: reverse and 1st but no 2nd and 3rd
time for a rebuilt transmission. its an internal failure and cannot be simply fixed
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-19-2010, 10:56 AM   #3
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
I would say you lost both of those forward gears and something internal failed so its rebuilt tranny time or rebuild the one you have.Your vacuum modulator line may have popped off the steel line from the engine but that should not caused the sudden loss of 2 forward gears when that happens usually the shifts between gears are delayed not lost completely.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 05-19-2010, 12:02 PM   #4
7ft stew
Would any 350/400 tranny work or is it Pontiac specific?
Old 05-19-2010, 11:12 PM   #5
bitchin85
bitchin85's Avatar
i believe the bolt pattern to the block it different from chevy to pontiac to buick.. etc
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 05-19-2010, 11:51 PM   #6
SCOTI
SCOTI's Avatar
Try shifting through the gears manually first. From a stand still, drop it into 1st/low gear. As you accellerate @ normal speed, try shifting into 2nd when the rpm's sound like it's time to shift.
If it shifts into 2nd, repeat the process for 3rd/drive. If it goes through the gears, the vacuum line came off the modulator down @ the transmission. It's common; especially when the rubber line gets fluid soaked & swells.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-21-2010, 12:06 PM   #7
theprestongroup
Yeah the exact same thing happen to me. I just shifted throught the gears to make sure that the tranny was shifting. Then I looked in the LMC catalog to find the location of the modulator and discovered the vaccuum line had slipped off. I put it back on and have been rolling ever since.
theprestongroup is offline   Reply With Quote
Old 05-21-2010, 09:56 PM   #8
Conundrum
Conundrum's Avatar
Buick, Oldsmobile & Pontiac share the same bellhousing bolt pattern and are commonly refered to as BOP transmissions. I believe Caddilac also used the same bolt pattern. Chevy has their own bolt pattern.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 05-27-2010, 08:12 PM   #9
383tbi
Not familiar with the 350 but my 700r4 had the same issue and found governor
gear stipped.Replaced with new and 15 mins later problem solved.
383tbi is offline   Reply With Quote
Thread Tools
Display Modes
