Old 05-20-2010, 10:49 AM   #1
jawilder
Windshield washer stays on... HELP!
I baught a 79 K20 a while back and the windshield washers didn't work. It looked like it had a new(er) washer motor, so I opened it up and found a broken spring... no problem. I stretched the spring to fit and played with the sprocket inside it. It seemed to be locked, so I got it moving.
After about an hour of tinkering with it I got the washer to work. Great! But now the miserable thing stays on whenever the wipers are on. At both speeds I get squirt, squirt, squirt...
Any ideas?
jawilder is offline   Reply With Quote
Old 04-06-2019, 09:48 PM   #2
Shtudwn
Re: Windshield washer stays on... HELP!
Have the same issue. Thinking is is mechanical but I have read more than a dozen posts without anyone actually diagnosing and solving the problem. Lets see if this post triggers more responses.
Thanks.
Shtudwn is offline   Reply With Quote
Old 04-07-2019, 06:56 AM   #3
Wgesnerjr
Wgesnerjr's Avatar
Once a long time ago (mid 80's) my mom had a caprice that had this problem. Took it to the shop and was told that when this happens, tthe wiper motor needed replacing. new motor with old pump took care of it.
I couldn't understand how the wiper motor affected the pump. Was told that the pump gets power through the wiper motor. The motor was not shutting off power to the pump. He said it takes a couple of rebuilt motors to get on that works right. He thought it was because when old motors that ran perfectly well but didn't stop the pump were sent back as cores, the rebuilder tested them for wiper function, thought they were fine, repainted them and sent back out; never testing the washer circuit.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 04-07-2019, 08:02 AM   #4
Greenlee
Greenlee's Avatar
In my experience, this is true. My wipers would not turn off immediately when the switch was turned off. I replaced the switch first and nothing changed. I replaced the motor and they worked better, but would not park at the bottom of the windshield when you turned them off. I ended up changing the switch again and still no change. Finally, I took the motor back and exchanged it. After the second motor the wipers work like they are supposed to.
Greenlee is offline   Reply With Quote
Old 04-09-2019, 02:48 PM   #5
rgunlock
rgunlock's Avatar
My 78 has the same issue with the washer pump not shutting off after a few squirts. Replaced the wiper/washer (integrated unit in 78) and it worked for a while and started doing the same thing again. I think it is just poor quality remanufactured wiper motors. I think my next attempt to fix this will be using a separate, dedicated washer pump.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 04-10-2019, 12:03 PM   #6
RedBed
RedBed's Avatar
I had the same problem with junky replacement motor/pumps. I did replace mine with an aftermarket "universal" pump. No more problems.
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 04-10-2019, 09:22 PM   #7
Robert Crandall
Junior Member
I had that problem with my 1978. It took weeks of looking, but I finally figured out the problem is mechanical. There is a wheel with a cam that operates with the windshield wiper motor. You activate the washer, the wheel makes one revolution, and a cam turns the pump off. On mine the cam is worn, so instead of turning the pump off, it bypasses the pump switch, and the pump runs continuously. The only fix was to buy a new windshield wiper motor, which I will not do until I need one for the wipers. I let it pump dry maybe 20 years ago, and never filled the water bottle. It may still pump when the wipers are on.
Robert Crandall is offline   Reply With Quote
Old 04-10-2019, 09:24 PM   #8
Robert Crandall
Junior Member
Forgot to note: I bought the truck new, and it is the original wiper motor that had (maybe still has) the problem.
Thread Tools
Display Modes
