Old 05-24-2010, 11:55 AM   #1
Vandals909
Tilt Column Switch
My 71 has the factory fixed steering column. I have a donor 1987 Suburban, will the title from that bolt into the 71? What years work?
Vandals909 is offline   Reply With Quote
Old 05-24-2010, 02:46 PM   #2
Vandals909
Re: Tilt Column Switch
Also my truck came with from disc brakes but it does not have a power booster. Will the suburban power booster work? What are the guys who are swapping to LS motors using for a power booster?
Thanks again.
Old 05-24-2010, 09:21 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you want it bad enough, both of those parts will fit, but neither is a direct swap.
Old 05-24-2010, 11:04 PM   #4
Vandals909
Is there an oem chevy or GMC tilt cloumn that will fit? What about the 73 and newer steering column is it a direct fit. I'am trying to upgrade to a tilt and save some money also (poss pull one from a junkyard).
Thank you!
Old 05-24-2010, 11:29 PM   #5
Longhorn Man
the only direct fit ones aren't cheap... the stock ones for these trucks.
After that, some old RVs had one that was a direct fit, but very hard to find.
After that, the common 72-81 van tilt, minimal mods, dirt cheap at many junk yards. It looks very very close to the original truck units too. I'm sure someone has a link to the needed mods
Old 05-25-2010, 02:25 AM   #6
Vandals909
So is the majority of the people on the site using a 67-72 tilt column? What about the one brothers makes?
http://www.brotherstrucks.com/prodin...number=RTSC72A
http://www.performanceonline.com/sto...at=1108&page=1
http://www.earlyclassic.com/catalog.aspx
The one from ECE says it is for 1969-1972, why wouldnt it work for a 67-68? My truck is registered as a 71 but has 67 front end and doors. Anyone know the difference.
Old 05-25-2010, 03:02 AM   #7
Vandals909
Think I found the article for the mods needed.
http://www.customclassictrucks.com/t...c10/index.html
Thread Tools
Display Modes
