Old 02-14-2003, 01:33 AM   #1
moose
door gap ????
Is this door gap to wide
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr
7I JIMMY 350 4speed daily driver/next prodject
99Yukon wifes
moose is offline   Reply With Quote
Old 02-14-2003, 02:19 AM   #2
bigvinnie
bigvinnie's Avatar
do you have more pics? A shot of the whole cab and door would give a better view.... looks like it might be a little wide, but a better pic would really help...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 02-14-2003, 03:46 AM   #3
casey
casey's Avatar
compare it to the front of the door, I tried to make mine about the same front and back, you just have to play with it alittle bit, some times it depends on how the window frame fits as well, theses trucks never had precision fit body parts.
casey is offline   Reply With Quote
Old 02-14-2003, 09:26 AM   #4
72MARIO
72MARIO's Avatar
Make Sure you have the fender on you may have no gap in the front . The gap looks Quite BIG to me
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-14-2003, 09:30 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
What I have learned (or so it seems) is that every door is different! I swear some are a tad bigger or smaller or ???
Anyhow, the gap on your door looks exactly like mine. The gap at the rear of the door is larger than the front on mine.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 02-14-2003, 03:22 PM   #6
Danny69'
The cab on my truck is a little messed up because the rockers were rusted out so bad for so long that it allow the jam on the dirvers side to tweak out a little bit, so it makes the gap in the back real big at the bottom but tight at the top. Also when I put the new rocker in, since the jam is back a 1/4 of a inch futher then it should be, the front of the rocker is set back too. Guess I just got stuck with a crappy cab when I bought the truck.
1969' LWB [Work in Progress]
Danny69' is offline   Reply With Quote
Old 02-14-2003, 05:40 PM   #7
sbrban
Assuming that your rockers are in the right location( oem or replaced) the front corner of your door should line up with the rocker. These trucks didn't always line up like that from the assembly line but that is the best starting point.As always thing don't always go as planned so you may have to adjust elsewhere.
you never have too many suburbans....
sbrban is offline   Reply With Quote
Old 02-14-2003, 06:32 PM   #8
moose
thanks for all the help. Danny I did not Know that I should have suported the between the door jam so it night have moved on me to. I'll know next time thanks again Moose
99Yukon wifes
Old 02-14-2003, 07:42 PM   #9
Danny69'
Hate discovering stuff like that, but you have to deal with what you've got.
Thread Tools
Display Modes
