02-14-2003, 12:44 PM | #1 |
ready for reassembly
What seats will fit 71 k10
hey guys,
Just wondering what seats can be easily put in my truck. I have a factory bench right now. It was reupholstered before i got it, so it looks good, but it's soooo bouncy! i've hit bumps on the highway doing 60 and nearly hit my head on the roof!! I would prefer a bucket, but a nice bench with a console or something would be good too. Any ideas on some good donor vehicles?? what have you guys used?? thanks Jason |
02-14-2003, 05:03 PM | #2 |
i have a bench out of a 90 to 98 chevy it dosent have a console but i like it alot and it bolts in very easily, i have also heard that ford benches work pretty well but i dont know personally
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-14-2003, 07:07 PM | #3 |
SLOW BUT SURE,BUT CLOSER
Alot of late models will work. Chevy, Dodge, Ford all has nice seats, find and pick what you want. Good luck.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
02-14-2003, 07:14 PM | #4 |
1996 60/40 split folding console power lumber and adj front to rear. would be nice I am looking for one having a tought time finding one thought !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-14-2003, 08:39 PM | #5 |
best idea
Check out these seats 99 model truck seats. built in shoulder straps
02-15-2003, 02:20 AM | #6 |
that's kinda what I had in mind, Jackal.....I really like the 99-present chevy 60/40 bench seats. They have adjustable lumbar, console and biult in seat belts! What truck is your seat from?
Also it looks like your truck doesn't have a gas pedal??? that's okay, mine doesn't either....I haven't been to the wreckers to find one yet! later
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
02-15-2003, 02:22 AM | #7 |
Recovering Truck Driver
I nabbed a set of buckets out of a 91 Lumina van for mine
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
02-15-2003, 02:26 AM | #8 |
I guess you could probably use just about anything then, right??.......maybe in the spring, i'll measure the original for dimensions, and hit the wreckers to find one that looks good
how much would a good seat with no rips or stains go for????
02-15-2003, 07:46 AM | #9 |
PROJECT LO-LYF
I just picked up a bench seat with the fold down arm rest out of a late model chevy for 75 bucs! What a Steal!
FOUNDING MEMBER OF THE "O-SH*T, THAT TRUCK IS LOW" CLUB PROJECT: LO-LYF Bagged 68 Shorty home.att.net/~justin.lewis |
02-15-2003, 07:55 AM | #10 |
Jackal I think I have seat envy... Were they a straight bolt in? Or did you have to re-drill?
O'l Buck: Did you have to re-drill? Anyone: If you re-drill the holes, do you use large washers on the backside to prevent tear through? Or is that really a problem? |
03-02-2003, 12:38 PM | #11 |
I ripped some seats out of a 92 crown victoria. 8 way with lumbar. I got some steel from home depot and made my own brackets. All you have to do is wire 12 volts and you are done. Didnt even have to raise them up either. All for 50 bucks! Just make sure you take a 12 volt source with you to the junk yard. The seats will not move with out juice!
03-02-2003, 12:53 PM | #12 |
Dreaminator
Mine are out of a 90 cutlass Supreme. Made brackets and shimmed the seat angle a little. Belts out of any late model GM truck bolt right into my 71. Good searching. Looks some guys have better bone yard choices than we do up north. Especially when its snowing and blowing. Good luck in your search.
The Dreaminator Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400. |
03-02-2003, 05:54 PM | #13 |
senior member
anyone know if there is more height under the seat of a newer style?
69 GMC bagged |
03-02-2003, 07:00 PM | #14 |
It's been awhile since I checked this thread 68_Step, yes, I did have to redrill the floor, but I suspect you would have to redrill for most any seat except for the stock seats.
03-02-2003, 09:28 PM | #15 |
Thanks O'l Buck!
03-04-2003, 10:08 PM | #16 |
sorry about being so slow to respond i was out for a week. Yeah i had to redrill. Just becareful to make sure you can get to the spot you put it for the hole. Everything lined up amazingly well on this one. i had to grind a little on the corner of an old thread mount to get my huge flat washers to clear. If i had it to do again i think i might drill the holes and weld on nuts on 2x2in plates onto the frame. That would have required removing the cab at the time but i had to do that anyways for some rust trearment, cab corners, cab mounts, etc. I picked up the set of seats for a mere 200 bucks. One was bent we tore it down to the frame and broke it and reset it.... kind of like a broken limb.
GL if any one would like i can help you look for a set here out of san antonio. these are out of a 99 ext cab trick door. I think they have more hieght under thm than most. On the driver side theres a big amp and under the middle seat i can fit my bio book and my physics book.... thats about 5 and a half inches gas pedals are for ppl with soft feet. heh... actually id rather have a pedal it might feel like im pushin more and i might not push so hard. lol Last edited by Jackal2k9; 03-04-2003 at 10:15 PM. |
Thread Tools | |
Display Modes | |
