Old 06-03-2010, 04:40 AM   #1
SPIRIT OF 76 CHEVY
SPIRIT OF 76 CHEVY's Avatar
Question Need a lil info on a rockcruser 4'speed trans
I just got this 69 swb and it's 350 4'speed I want to put a auto in it so my Q is what is this Rockcruser trans whort$$ I was told that it is a vary good trans and whort alot of money it only has 250 miles on it and it's so clean you can eat off it so plz let know what you guys know about
Stan's short bed fleet
69 custom deluxe swb
69 custom swb shop truck
70 custom sport truck swb
72 GMC super custom swb
72 Custom/10 swb inline 6 auto p/s p/b
77 silverado swb
86 Buick Grand National
92 silverado sport swb
06 silverado crew cab
07 caddy sts
08 f250 4x4 crew cab Sold!!!
12 dodge ram 1500 big horn
SPIRIT OF 76 CHEVY is offline   Reply With Quote
Old 06-03-2010, 05:51 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Need a lil info on a rockcruser 4'speed trans
The Muncie M22 car 4 speed is often referred to a the "rockcrusher". Is this what you have in your truck? If it is the original truck tranny (SM465), it is worth about $100.
Blazer1970 is offline   Reply With Quote
Old 06-03-2010, 06:51 AM   #3
cdowns
cdowns's Avatar
of course it might take ten years b4 somebody gives you the $100
Old 06-03-2010, 07:18 AM   #4
rsavage
rsavage's Avatar
Are you sure you are not confusing "rock crawler" -what the stock SM465 truck transmission is often used in with a muncie M22 car 4 speed which has straight cut gears and is called a "rock crusher"? It is a much smaller transmission and has an aluminum case. The truck tranny is often used in off-roading and rock crawling as it is very strong, has a cast iron case, and a very low 1st gear. They go, as CDOWNS has said, for not much money. If it is the car transmission (it would have a shifter on it which is attached to the left side of the tail shaft and you would be able to see the shift linkage rods along side the transmission) it would be worth some good money. If your shifter is tall and comes out of the top of the transmission, it is the stock truck 4 speed.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-03-2010, 01:15 PM   #5
SPIRIT OF 76 CHEVY
this is not the stock trans the truck was a 3 on the tree I talk to a guy on craiglist he built race cars and had 5 or 6 of these trans he sold a junk one for $1200 and good one for $3500 he said they our hard to find it is not stock at all
77 silverado swb
07 caddy sts
Old 06-03-2010, 01:58 PM   #6
breeh
Recovering 67-72 Addict
breeh's Avatar
Given that it is a true M-22 then it sounds like you already know what it may be worth. Personally, I don't like them. They were geared for road racing (late '60's trans am circuit). I had one for awhile in a 67 Camaro and replaced it. It's value would be to a period correct restoration project.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-03-2010, 02:01 PM   #7
rsavage
rsavage's Avatar
You can buy new ones for about 1800 with no core
http://www.tbtrans.com/muncie_4_speed.htm#new_unit
Obviously someone with a need for a correctly dated transmission for their restore would probably spend more than that for an old one.
1961 C1 Corvette
2021 Durango RT 5.7
Old 06-03-2010, 02:35 PM   #8
raycow
I agree. Not a very practical transmission for normal driving, but they are definitely worth major $ to someone doing a stock resto.
Ray
raycow is offline   Reply With Quote
Old 06-03-2010, 02:40 PM   #9
Shane
Shane's Avatar
why not ask him what he would give you for it?
Shane is offline   Reply With Quote
Old 06-03-2010, 03:58 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
First you need to be sure of what you are looking at. Not all Muncies are the M22 Rock Crusher.
http://www.yearone.com/updatedsingle...nfo/muncie.asp
http://442restoration.homestead.com/...e_4_speeds.htm
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-03-2010, 08:23 PM   #11
c1069
c1069's Avatar
My friend has one 4 speed saginaw for sale he is asking $200
c1069 is offline   Reply With Quote
Old 06-03-2010, 09:13 PM   #12
Doug Garland
Apples to oranges there. A Muncie, especially a M-22 is nothing like a Saginaw, price wise or other. The only way to know what it is , is pull the side cover, and look at gear angle. The case could be marked as an original M-22, but with the influx of gearsets available in the aftermarket, there is no telling what you have till you pull it and look inside. On side of transmission, it should have P and a date code, then A,B or C. (If it is a 1968 or later transmission). A=M-20, B=M-21, C=M-22. This was the original coding for the transmissions.
Saginaw transmissions used to be $25 to $50 each, and lasted usually a week to a month. The comparable Muncie would bring $200-300, and lasted till you hooked up the tires good. The prices for Muncies have climbed to $300-500 for a good used, and $700-900 for a used M-22(depending on internal condition). Rebuilt ones are considerably more. Last M-22 I had, I bought for $600, sold for $800, and the guy put a kit in it, with new brass, and it sold for $1400. That was almost 10 years ago.
Doug Garland is offline   Reply With Quote
Old 06-03-2010, 09:22 PM   #13
71 super
71 super's Avatar
The saginaw trans was pretty common and alot of the models used in vegas and such have found their way into larger cars and trucks. Long and short, not as common as they used to be simply because they break, especially if you horse them around. the mincie on the other hand -m21 or m22 is pretty desireable. Had a 22 several years ago and as stated earlier not so good on the street, sold it and replaced with TCI 400 th with reverse manual valve body and brake.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-03-2010, 09:24 PM   #14
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I can tell you I have blown up muncies, M-21's and M-22's, and saginaws. When the saginaw goes it doesn't feel as bad because you can find another cheap one and go. The muncie is a different story. I had these behind a 650hp 383 stroker in a 72 rs camaro and those saginaws held up longer than the muncies for some odd reason.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Thread Tools
Display Modes
