Old 06-03-2010, 08:00 PM   #1
lt704
hei distibutor
Hi Guys, I have a accel dizzy in my 350 engine on my 1968 C10. I just picked up a msd hei cap and rotor from our local performace store, When i picked it the man said that my accel coil( 4003) would fit my new msd cap . Is this correct, The only reason I bought the msd cap was for the color ( red ). I didn't loke the brown accel cap. Will this set up work ?. I also bought taylor red hei spark plug wires. Thanks for the help Russ
lt704 is offline   Reply With Quote
Old 06-03-2010, 10:39 PM   #2
1969stepside
1969stepside's Avatar
Re: hei distibutor
i dont see why it would not fit but i dont really know procomp has a full distribitor with coil and a red cap for 60.00 or less
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 06-04-2010, 03:09 AM   #3
tim21391
tim21391's Avatar
Re: hei distibutor
it should.. im running an accel distributor and i forgot to put the button in and it destroyed my cap and so i got a new one and figured id go with msd cap and rotor and i just used my accel coil.. and it fit just fine.. and ran just fine
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-04-2010, 09:03 AM   #4
lt704
Re: hei distibutor
Thanks guys, I like the red color of the cap. Tim i am doing the same thing as you did, thanks for the input....Russ
Old 06-04-2010, 07:25 PM   #5
tim21391
tim21391's Avatar
Re: hei distibutor
no problem. just dont overtighten your one coil screw going down to the ground little thing inside the clamp i stripped out and had to get another.. but ya it al lfits perfectly and runs same
Old 06-05-2010, 02:11 PM   #6
lt704
Re: hei distibutor
Thanks for the update Tim, Russ
Old 06-06-2010, 11:16 PM   #7
tim21391
tim21391's Avatar
Re: hei distibutor
no problem
Thread Tools
Display Modes
