Old 06-04-2010, 11:57 PM   #1
Baged72
Baged72's Avatar
I still cant get auto meter gauges to stick to cluster
I bought a full set of auto meter sport comp gauges... I pretty much just have my outter gauge cluster and im trying to jb weld, epoxy the gauges to the back circles so they sit behind the cluster but nothing i find is sticking, any ideas??
Ive tried JB weld and Plastic Cement 3500psi strength.
The outer ring on the gauges lookr to be aluminum??? And the cluster is obviously some type of plastic.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 06-05-2010, 02:02 AM   #2
chevyblazer
chevyblazer's Avatar
Re: I still cant get auto meter gauges to stick to cluster
have you tried here in tj its called kola loca shuold it be crazy glue
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 06-05-2010, 11:46 AM   #3
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Plain old hot glue might work as well...I have used it for lots of things and it impresses me everytime...
1969 Chevy C10 Custom Camper - "Frame On" Restoration
Blueprint 383 w/ 405hp@5200rpm & 441ft-lbs@4200rpm / Jegs TH350 w/2300 Stall / Drivelines NW 2-Piece Shaft / stock 3.08's / CPP 4" Drop Rear, 3.5" Modular Drop Front
Beatcoaster is offline   Reply With Quote
Old 06-05-2010, 11:51 AM   #4
gkesseru
gkesseru's Avatar
I've used hotmelt glue before on guages. Just scuff up the back of the panel first. It also works great for holding wires in place. Don't use the low temp stuff.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 06-05-2010, 12:01 PM   #5
Baged72
Baged72's Avatar
Where can these items be purchased??
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 06-05-2010, 12:39 PM   #6
bjohn3x
no no no silly. If you want to do the "autometer behind the bezel install", look here: http://67-72chevytrucks.com/vboard/s...d.php?t=110613
I know some of the pics are missing but you get the point. I did this and here are the results:
1969 Chevy 1/2T SWB w/515HP 383, Viper 6 speed (.50 OVERDRIVE BABY!), 3.73 POSI rear
1965 Mustang w/367HP 289, 5 speed, 4.11 coming
bjohn3x is offline   Reply With Quote
Old 06-05-2010, 01:00 PM   #7
1LoC10
Insert Title Here
1LoC10's Avatar
Ive never heard of anyone gluing gauges before?
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-05-2010, 01:18 PM   #8
ERASER5
ERASER5's Avatar
Psst. Your truck is on empty.
Nice gauges.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-05-2010, 01:41 PM   #9
Baged72
Baged72's Avatar
All i have is the outter shell, that other process cannot be done and looks so much more time consuming i rather just glue them in and put it back in, in a matter of minutes.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 06-05-2010, 02:03 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
If your in that big of a hurry, better use duct tape. Seriously, if it's worth doing, its worth doing it right.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-05-2010, 02:25 PM   #11
bjohn3x
lol, yup tru that. You can pick up a used gauge bezel complete usually for like $20-$30 at a local swap meet or online somewhere. Especially if it's all F'ed up and the gauges don't work.....'cause all you need is the hardware from the back. my 2 cents...otherwise good luck with the glue and tape
Old 06-05-2010, 02:26 PM   #12
Baged72
Baged72's Avatar
Don't see how i could use tape other wise i would plus that wouldn't give it a secure fit.
I am not really looking for a glue, more like an epoxy/weld for plastic&aluminum.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 06-05-2010, 05:39 PM   #13
junkyardjohn
junkyardjohn's Avatar
I'VE DONE A COUPLE OF I.P.s WITH AUTO-METER GAGES. I ALWAYS PUT THEM IN FROM THE FRONT & SECURED THEM WITH THE HORSHOE TYPE CLAMPS THAT CAME WITH THE GAGES. I UNDERSTAND THAT IT'S NOT EXZACKLY WHAT YOU'RE TRYING TO DO... BUT MAYBE IT'S A BETTER ALTERNATIVE THAN GLUE OR TAPE. JOHN http://67-72chevytrucks.com/vboard/a...9&d=1073868208
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-05-2010, 09:50 PM   #14
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Same here. The bezels of the gauges slide into the IP just right & a little tight. It looks cleaner too.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 06-06-2010, 01:12 AM   #15
frost89434
frost89434's Avatar
Here is a pic of the one in my 68. I just slid them in from the from and used the clamps like john said. Turned out great IMO.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 06-06-2010, 10:11 AM   #16
Shane
Shane's Avatar
they don't attached to the plastic face bezel ... they attach to the metal "box" that the original gases are attached/made on to.
you are about to ruin an entire set of gauges if you use JB Weld/Super Glue or some other half-ass method of attaching.
Shane is offline   Reply With Quote
Old 06-06-2010, 10:19 AM   #17
my67c20
There is a new product on the market called RTV / Silicone. Works great on holding together fishtanks, bathroom enclosures, sealing windows. Actually i would go to the home improvement store and look at the silicone adhesives. Odds are there is something there that will meet you needs. I would use the hot glue to place them then add a bead of silicone around each one and let cure up. Nice thing it comes in different colors so if you have a small gap you can hide it.
my67c20 is offline   Reply With Quote
Old 06-06-2010, 11:34 AM   #18
junkyardjohn
Originally Posted by shane View Post
they don't attached to the plastic face bezel ... They attach to the metal "box" that the original gases are attached/made on to.
You are about to ruin an entire set of gauges if you use jb weld/super glue or some other half-ass method of attaching.
i've done them both ways shane... Just the bezel (i did put a aluminum faceplate over the bezel, but i'm sure it would work without one too) & cut right thru the metal innards of a stock cluster also. Lighten up.. This guy appears to be just learning. john
junkyardjohn
DON'T RENT U-HAUL
Old 06-06-2010, 01:10 PM   #19
seafoam68
seafoam68's Avatar
This is what I am trying to do and I have the phantom gauges. My question is where did you guys find the 3-3/8" Phantom gauge? I have searched high and low, including the AutoMeter web site and can't find one in that size. Are they no longer made maybe? Help??
seafoam68 is offline   Reply With Quote
Old 06-06-2010, 01:32 PM   #20
bjohn3x
yup, discontinued. I've seen people put in a 2 5/8 clock there, but looks horrible. I found a NOS Phantom 3 3/8" gauge on ebay...I got super lucky.
Old 06-06-2010, 06:39 PM   #21
71 super
71 super's Avatar
If you really want to glue them in, Loctite makes a product called "PLASTIX" $5.68 at lowes or similar. It will flex yet is super tough- used it to reinstall a end cap in a old ball bat for a kid not long ago- kid was using it in high school varsity games and it is still good to go. You have a 20 minute window to work in, and it beats the other stuff out there. Piece advice, keep some isopropinal alcohol to wipe immediately after you get parts together. If not you will have residue you cant get rid of.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Thread Tools
Display Modes
