Old 06-06-2010, 12:56 AM   #1
thelonerife
thelonerife's Avatar
454 core for sale
I got a 454 core motor. This motor has standard bore so it hasn't been rebuilt. It is a 2 bolt main motor. It is currently at my rebuilders shop so I don't have the #s. its from a mid 80s rv.I found a small block and had him do it for me instead since it had everything with it.
I have two sets of heads with it. They will need rebuilt also. Would like it to be picked up but I can meet you somehere if you cover my gas. I'll offer the buyer other big block stuff if he passes I'll post it up here.
454 w/2 sets of heads 500.00
The valve covers in the pic are not included. I already sold those. The ones included are stock.
Last edited by thelonerife; 06-06-2010 at 06:20 PM. Reason: added its a 2 bolt main
thelonerife is offline   Reply With Quote
Old 06-06-2010, 08:31 AM   #2
skeeterbug
skeeterbug's Avatar
Re: 454 core for sale
lone rife i am very interested what all do you have for this block, i need another engine to build before my small block goes caput. i just bought that sway bar about a month ago from southern c10 so i am sure we can work out something on delivery or gas if the block and heads are good.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 06-06-2010, 12:47 PM   #3
thelonerife
I'm not sure what you are asking about so I'll just try to tell you what I know the motor has and what parts I have to make it work.
Motor. block 2 bolt main,rods and caps,crank,pistons,peanut heads and higher flowing 3820 heads. valve covers,new oilpan. No intake or carb or pulleys or ps brackets.
I want to sell the motor first and let the buyer pick from the accessories list what they want so they are not for sale right now. I will let the person pick what they want then I'll sell them later. Theres probably more this is just off the top of my head.
Accessories not included (extra $)
- nos fan shroud,exhaust manifolds and pipes that turn back,fuel pump, starter heat shield,ps remote reservoir with hose,flexplates one for 400 turbo only and one with dual bolt pattern for t350 or 400.upper alt bracket for 72style, 1''drop big block springs,
Old 06-06-2010, 01:52 PM   #4
skeeterbug
skeeterbug's Avatar
ill pass, looking more in the lines of 4 bolt, thanks though
2013 best 7.39
2014 best-7.38
Old 06-06-2010, 05:57 PM   #5
thelonerife
No problem. I've edited the original post to include that its a 2 bolt main. thx.
Old 06-06-2010, 06:12 PM   #6
w314speed
The accessories! Is the NOS fan shroud for a 69-72 BB chevy truck? If so, I'd like to be first in line to buy! How much? Thanks, Dan
w314speed is offline   Reply With Quote
Old 06-06-2010, 06:14 PM   #7
thelonerife
Dan, I am going to sell the motor first. The accessories aren't for sale right now. thx.
Old 06-07-2010, 08:17 AM   #8
w314speed
Bump for the 454! Chuck keep me first in line for NOS fan shroud when engine sells! PM with $ for shroud and shipping to 30127. Thanks, Dan
Old 06-10-2010, 08:23 PM   #9
thelonerife
ttt
Old 06-12-2010, 11:03 PM   #10
thelonerife
bump
Old 06-14-2010, 08:57 AM   #11
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Would you be interested in doing some trading on a virgin 400 sbc 2 bolt complete minus valve covers? I have had this motor in the garage for quite a few years and my buddy came over a week or so ago and wanted the finned valve covers for his Rat Rod or it would still have the factory valve cover's. I have been saving it to build for a Camaro project but I have decided to start messing with big blocks after I got my '69 Chevy truck. Thank you
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 06-14-2010, 09:26 PM   #12
thelonerife
I'm really wanting to sell it. I'm doing some liquidating.
Old 06-15-2010, 12:30 AM   #13
Camaro_nut2001
Sounds good, if you change your mind just let me know.
Old 06-17-2010, 07:28 PM   #14
thelonerife
will do.
Old 06-26-2010, 08:54 PM   #15
thelonerife
bump
Old 06-27-2010, 04:55 PM   #16
thelonerife
I picked it from my rebuilder yesterday. Its still all apart so you can see its in good shape.
Thread Tools
Display Modes
