Old 06-08-2010, 03:18 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
van tilt column, installing lower gasket/plate???
Hi everyone,
I am getting to the point of mocking up my van tilt column and am curious how do I remove the firewall mounting plate from my original non tilt column and install the new gasket and plate on my tilt? Both of these are auto columns so they have the arms at the bottom so you can't just slide these parts off.
I don't recall anyone talking about this recently.
Thanks!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-09-2010, 05:31 PM   #2
chevy_mike
chevy_mike's Avatar
Re: van tilt column, installing lower gasket/plate???
Ideas anyone???
Old 06-09-2010, 09:49 PM   #3
70shortfleet
70shortfleet's Avatar
Sorry to say this but if you want to do it the right way, you have to take the column apart and slide the upper and lower boots on before you put it all back together! OR you can bend the bottom part over until you can slide the boots on and bend it back and hope you do not weaken metal too much. Hope this helps
70shortfleet is offline   Reply With Quote
Old 06-09-2010, 11:01 PM   #4
chevy_mike
chevy_mike's Avatar
I was afraid of both of those options... thanks for the confirmation. I really don't want to pull the tilt column apart as it looks like PITA compared to the non tilt.
Old 06-10-2010, 07:08 AM   #5
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I was going to take my tilt apart to replace the lower gasket but I didn't know how. So I went the cheap route and had it done for free by bending the arm and slidding it over. Just a thought I didn't want to do it that way but I was going to be charged money I didn't have to have it done the right way & trust me it wasn't goint to be cheap at lease an hours worth of work..
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Thread Tools
Display Modes
