Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-11-2010, 11:57 AM   #1
mothertrucker424
mothertrucker424's Avatar
s10 tpi q
i got a 95 s10 single cab i just swapped in a 89 tpi motor obd 1
with a custom 23" suspension lift kit and 2" body lift with a 700r4 w/ kickdown cable
has anyone else here done this?
i have a few problems radiator to w/p clearance?
what radiator to use?
what headers to use?
do i need maf? seen alot without
any help would be great will post some pic's asap
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 06-11-2010, 11:04 PM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: s10 tpi q
I cant answer all these questions especially the S-10 body ones but I do know a little about the TPI setup.
If your 89 has the MAF sensor and it does not have any problems (runs well) then I wouldnt worry about changing the system over to a non MAF setup. You would need to change several parts to loose the MAF.
A speed density setup (non MAF) is a diffrent harness, computer and several sensors.
I bought a TPI setup without the harness or computer and I am going with the speed density setup. I hope I have all the parts now, the engine is out and the tranny in the shop so as soon as I get that back I will be putting it all together. I am tired of buying stuff I want to get it running
good luck
chevytruckluver is offline   Reply With Quote
Old 06-14-2010, 03:05 PM   #3
Tink
Tink's Avatar
Re: s10 tpi q
You could probably re-locate the radiator inside the core support... I've seen that done on several V8 S10s... unless the thinner covette radiator will give you the clearance.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Thread Tools
Display Modes
