Old 06-18-2010, 07:20 PM   #1
centexan
14 bolt 6-lug?
Is there such a thing? I would like to get/build one for my 74 jimmy and wonder where to start. Thanks!
1989 Chevy Suburban v1500
centexan is offline   Reply With Quote
Old 06-18-2010, 09:13 PM   #2
raycow
Re: 14 bolt 6-lug?
Sure enough. You will find them under the 3/4 ton "light duty" 88-up. This is the 9.5" semifloater.
Ray
raycow is offline   Reply With Quote
Old 06-18-2010, 11:00 PM   #3
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: 14 bolt 6-lug?
I would highly reccomend full float and hub upgrade.. In which case you would be checking any old junkyard for a DRW 14bolt ff (Its the one that has a removable pinion gear case thingy) and check these out..http://pirate4x4.com/forum/showthrea...4bolt+lug+hubs
Full float has some very genuine advantages..
Eturnit3 is offline   Reply With Quote
Old 06-19-2010, 12:04 AM   #4
AJs72K5
AJs72K5's Avatar
Re: 14 bolt 6-lug?
The 14FF is probably one of the easiest, cheapest, and strongest axle upgrades you can do on the rear. However, I'd recommend going with the SRW (single rear wheel) axle as the width will be closer to the factory width of the 10 bolt on your truck. The SRW, like the DRW (dual rear wheel...dually) has the removeable pinion housing on the snout. Its not the same as a Ford 9" or Toyota 3rd member. Once the gears are set up on the 14FF, you'll wanna leave the pinion alone.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-19-2010, 12:51 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 14 bolt 6-lug?
Ray
My 1994 K1500 GMC Sierra has one... came from the factory that way.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Thread Tools
Display Modes
