Old 06-20-2010, 01:35 AM   #1
jasonb72
PorterBuilt Man Crush
few more updates..PB...Z06 brakes....
SO I finally got the PB rear all mocked up and ready for the custom 9" to be built. I also got the KORE3 C6 Z06 big brake kit. I have to wait for some wheels before I can put the brakes on up front since they are almost as big as the wheel I have for mock up at 14"'s baby.
I am waiting for my hookup to get me the 6piston front and 4piston rear Z06 calipers.
Here are the money shots for the picture lovers.
nexit up Custom 9", hydraulic dual friction clutch, TKO600 5 speed, and then a pair of TWINS for the rear ( I will let you think about that one)
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 06-20-2010, 01:37 AM   #2
jasonb72
Re: few more updates..PB...Z06 brakes....
More
Old 06-20-2010, 02:04 AM   #3
draggin86
draggin86's Avatar
so freaking sickkkk i love the zo6 upgrade that is going to be balllerrr
draggin86 is offline   Reply With Quote
Old 06-20-2010, 03:08 AM   #4
SCOTI
SCOTI's Avatar
You 'da man..... That was too much extra coin for only .600" larger brakes. Those 4-pot calipers do look sweet. Are you going to use actual Z06 units or PBR parts?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-20-2010, 08:13 AM   #5
Wild83C10
Wild83C10's Avatar
Rear mount TTs?
What are you doing for an e-brake?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 06-20-2010, 09:14 AM   #6
jasonb72
Going with GM Z06, I have a buddy who can get them for me for cost, so I did not get the calipers through KORE3
Old 06-20-2010, 09:15 AM   #7
jasonb72
Don't konw yet, probably a brick unless I can rig a roll stop control to work
Originally Posted by Wild83C10 View Post
Rear mount TTs?
Old 06-20-2010, 09:23 AM   #8
smbrouss70
smbrouss70's Avatar
If you are going with a 9" rear, there are plenty of pinion mounted parking brakes out there. I used Kore3's factory style drum-in-hat parking brake setup on a 10-bolt, but man does it add to the cost of the rear brakes!
I'm assuming that you will be running 20's in the front? Keep in mind that you will probably need flush-mount valve stems if the tire valve is behind the spokes like most custom wheels are. Ask me how I know.
It looks nice, and I'm thinking that maybe I should have stepped up to the aftermarket rotors instead of the stock ones. Oh well, I can change those later.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-20-2010, 03:28 PM   #9
jasonb72
Ive looked at the those before, just don't know if I will gave ground clearance issues with it.
I know I will need to switch over to the flush mount stems.
The aftermarkets are nice, I will need to change the color to match the colors on the truck, same with the calipers.
Yes 20's up front.
Old 06-20-2010, 03:29 PM   #10
jasonb72
You guessed the twins correctly.
I will be doing a STS twin turbo kit with them mounted in the bed or what will be left of it.
Old 06-20-2010, 06:15 PM   #11
Painter D
Painter D's Avatar
Twins in the rear will definately be cool.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 06-21-2010, 03:19 PM   #12
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks like I will have to watch this one too...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-21-2010, 04:03 PM   #13
WellBilt Kustoms
What are the specs on those wheels? (who makes them, size, offset, ect.) They look sick! Deep lip.
Nice build!!!
WellBilt Kustoms is offline   Reply With Quote
Old 06-21-2010, 04:09 PM   #14
smbrouss70
smbrouss70's Avatar
Man, I just noticed that your axle is up-side down. The stud for the panhard bar should be on the top-right of the pumpkin, not the bottom-left.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-21-2010, 05:59 PM   #15
jasonb72
Bonspeed, 20x10 4"BS quickilver's
Nice build!!!
Old 06-21-2010, 06:01 PM   #16
jasonb72
Good eye, I know this is just for mock up so I can get it rolled to the guy building the custom 9" When you are doing a build like this by yourself and in a half full 2 car garage there is not a lot of room for turning things about.
I knew it was going to be pulled apart at the rear end shop so it did not matter.
Old 06-21-2010, 06:04 PM   #17
smbrouss70
smbrouss70's Avatar
I completely understand about building by yourself in small spaces, I just didn't want you to have 1 forward and 4 reverse gears when you were done.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-21-2010, 06:05 PM   #18
jasonb72
Thanks I always invite extra sets of eys on things like this.
Old 06-22-2010, 02:07 PM   #19
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
nice set up.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-26-2010, 01:56 PM   #20
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Did you design your own rear caliper brackets? If you did, it would be simple to add e-brake to your setup with the corvette style e-brake backing plate. You would have to cut out a new bracket and shim it accordingly but should be pretty simple.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-26-2010, 06:37 PM   #21
jasonb72
THis is the kore3 setup. They have one it was just 600 extra, I will find a cheaper solution....I hope
Old 06-27-2010, 09:21 AM   #22
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I cannot wait to see the twins mounted in the rear....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-28-2010, 12:20 AM   #23
jasonb72
I feel the same way, I have to decide whether to buy the twin kit or the Fuel injection system first, one may have to come before the other......
Old 07-15-2010, 06:25 PM   #24
jasonb72
New pics showing the loading up and moving to Peyton Performance for the custom 9"
Having them do the bed side tubbing and welding the PB rear kit to the frame.
Old 07-15-2010, 06:27 PM   #25
jasonb72
more
Thread Tools
Display Modes
