Old 06-21-2010, 09:08 PM   #1
Racie
Question Do you have to narrow the stock rearend for the 20x15
Does anyone know the backspace required to run the stock rear end on the 68' fleetside to run the 20x15's? I will be doing the tub mod to the bed but I was hoping to not have to narrow the rearend. Anyone know the answer?
Racie is offline   Reply With Quote
Old 06-21-2010, 10:39 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Do you have to narrow the stock rearend for the 20x15
I assume you are lookig at 20" tall x 15: wide?
I have 8.75 negitive offset to fit my 18.5" wide Hoosiers radials
No the rearend is not narrowed - you do have to use non tapered springs, relocate or move the ebrake cable out of the way and cut the bed back flush with the frame and make a larger tub
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 06-22-2010, 12:16 AM   #3
chevyblazer
chevyblazer's Avatar
depends on how wide they are from center outsides
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 06-22-2010, 05:49 AM   #4
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Do you hav any pictures from the back of those Hoosiers mounted I'd like to see what the look like on our trucks.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 06-22-2010, 07:00 AM   #5
Racie
I will be ordering the wheels so I will have them made to fit. I really don't want to narrow the rear just to do it. If I have to get into narrowing the rear end I may just stick with a 20x10 and run 295/40/20 tires.
Old 06-22-2010, 07:02 AM   #6
Racie
Thanks and yes I do mean 20" tall plan on ordering Billets for the truck and I will be having them built. Thanks for the good info...
Old 06-22-2010, 07:23 PM   #7
1968SWBBigBlock
Active Member
Attached will be some photos from behind -I dropped the rearend a couple of more inchs since I took this photo
1968 SWB
Old 06-22-2010, 09:36 PM   #8
Racie
Absolutely bad ass! Beautiful truck...Thanks for all the info and help!
Old 06-23-2010, 02:48 AM   #9
petey-pablo
"THE GREEN GOBLIN"
Nice looks good all rubber from the back any pictures of the inside of the bed? I am looking to do something like this to my truck as well but don't want to have to narrow the rearend, and yours just looks bad ass. I have some pictures of another board members truck that did the same just cut the bed and widden the wheel wells. I have to find it and start doing the research to get this project on the way.. Thanks
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 06-23-2010, 08:15 AM   #10
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I did mine cut the bed and the wheel tub about an inch in the rebolted the tub in.I added 5" to the tub..my stock ralleys have 4" of back space added to them and I have 31x15.5x15's
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-23-2010, 08:46 AM   #11
1968SWBBigBlock
Active Member
Sorry I do not have any pictures of the bed - at least not worth looking at.
From inside the bed it looks totaly stock, Hottrucks shot some great photos for your consideration.
1968 SWB
Old 06-23-2010, 09:29 AM   #12
Hottrucks
Hottrucks's Avatar
heres one of the bed not great but you get the idea..I painted the inside of the bed with semi rustolium black to clean it up..but keep in mind my bed gets used pretty hard as you can see this is what it does on the weekends .... LOL ....
Old 06-23-2010, 09:54 AM   #13
Hottrucks
Hottrucks's Avatar
on a side note if your tires are more that 29" tall and you have a c notch the tires are going to hit the top of the tub...my truck was built for 29" tire but since I got a deal on a set of 31x15.5's and now 31x16.5 wrinkle walls I can't dump to the bottom of the notch..I have no idea how close it is because I can get my fat head under to see...lol
I would also like ot find a early rear axle I think the extra 1/2" narrower on each side would help sidewall to bed clearance...its REALLY cose now and does rub on occation..another issue that would be resovled by going back to the 29's
Old 06-23-2010, 11:34 AM   #14
petey-pablo
"THE GREEN GOBLIN"
Thanks This mod looks very easy to do on Metal, beds what about a wooden bed ? Would it be the same or would I or anyone else run into problems on a wooden bed I want to do this to my 72.
Sorry Racie didn't mean to jack your thread.
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 06-23-2010, 11:44 AM   #15
Racie
No problem bro! Just trying to pick up as much as I can so I won't be fixing mistakes they can be costly.
Old 06-23-2010, 11:46 AM   #16
Hottrucks
Hottrucks's Avatar
Aren't the wheel tubs the same?? If I had the availablity I would have used another tub to make the patch to widen it.It would have kept that ridge in the tub to make it look more stock
Old 06-23-2010, 06:56 PM   #17
petey-pablo
"THE GREEN GOBLIN"
Yes wheel tubs are the same but dont you guys cut the bed alittle too I would asume the wood bed is made differently around that area. Metal bed has more support I would think maybe i'm wrong.
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 06-23-2010, 07:15 PM   #18
Hottrucks
Hottrucks's Avatar
yea I had to cut about 3" out...and there one support mid wheel that had to be cut.. heres a pic of the bottom of my bed before the work also notice the line..that what needed to be cut out
Thread Tools
Display Modes
