![]() Join Date: Nov 2009
Side Vent Glass Issues
When I go to open the side vent glass, the glass and latch literally come off in my hand... the entire glass piece with the handle attached to it. (Nearly dropped it on the freeway the first time I tried to use it!!)
So obviously, I need to repair it. Looking at page 19 of the LMC catalog, and it breaks down every component to the vent windows... but I have no idea what parts I should order. Can anyone help? Called LMC, but the people who take the orders don't have a clue. |
Re: Side Vent Glass Issues
Your local glass shop may be able to repair it. It might be worth a trip to visit them.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#3 | |
![]() Join Date: Feb 2010
You need item No. 3 in the LMC catalog. Part no. 30-5935 rubber wedge strip. You scrape and clean off the old rubber wedge strip from the window glass. Mine was attached entirely to the glass portion. You then soak the new wedge strip in oil of some type. I used my wife's sewing machine oil. WD-40 would probally work. You carefully wrap the strip around the glass and then slowly insert the window back into the metal strip. Take you time, light taps using a rubber or plastic end mallot helps. Hope this helps. PS Plan B- or you could apply some black weather strip and shove it back in. It will be tough to disassemble if you ever need to. Dale
1969 GMC SWB FLEETSIDE ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR DALE JONES MY BUILD THREAD: "69 GMC SHORT FLEET" http://67-72chevytrucks.com/vboard/s...d.php?t=388447 Last edited by djmachinist; 06-23-2010 at 07:48 AM. |
Most excellent help my friend. Thank you!
![]() Join Date: Dec 1999
I use dishwashing liquid like Joy, Dawn or ect. instead of oil. Oil breaks down certain types of rubber products.
Thread Tools | |
Display Modes | |
