Old 06-23-2010, 04:30 PM   #1
sluginxlt
sluginxlt's Avatar
brake problems?
my 1967 has all drums, i was driving it daily while i was doing a solid axle swap in my ranger. some times brakes would feel soft the first few minutes and other times the first few minutes of driving it no matter how lightly i tried to push the breaks they would lock up but after a minute or so they would go back to normal. So i finished the ranger and the fuel pump went out on the 351 gmc so i let it sit all winter do to lazyness. I found a fuel pump and got her running, but when i went to stop, no breaks! All the fluid was gone out of the master cylinder but never seen any leak on the ground or anywhere on the truck. any ideas on what happened? also when i was driving it daily break fluid would slowly dissapear but never seen a leak.
67 gmc long bed 351v6
sluginxlt is offline   Reply With Quote
Old 06-23-2010, 04:41 PM   #2
cdowns
cdowns's Avatar
Re: brake problems?
did you remove the drums to check for leakage and shoe conditions?
Old 06-23-2010, 05:05 PM   #3
sluginxlt
sluginxlt's Avatar
Re: brake problems?
not yet
Old 06-23-2010, 05:23 PM   #4
1-PU70
1-PU70's Avatar
Re: brake problems?
Did you look under the mat or carpet under the brake bedal? If no power brakes look there. If power brakes look in the brake booster. Might be leaking from rear of master.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-23-2010, 05:27 PM   #5
sluginxlt
sluginxlt's Avatar
Re: brake problems?
has power breaks, i was guessing brake booster but have never messed with one at all. sounds dumb but how do i check for fluid in there?
Old 06-23-2010, 06:23 PM   #6
michael bustamante
michael bustamante's Avatar
Re: brake problems?
fluid might be in the booster due to a bad seal, also look behind the tires for wetness, (i.e a leaking brake cylinder)
1967custom
michael bustamante is offline   Reply With Quote
Thread Tools
Display Modes
