Old 06-28-2010, 10:55 PM   #1
BigRed76
BigRed76's Avatar
Lift kits?
Dont mean to write a book here but I searched the forums and didnt really find what i was looking for. I am wanting about 6 inches of lift on my '76 shortbed 4x4, but need opinions on how to go about doing it. My original plan was to get front springs, blocks, sway bar drop brackets and extended brake lines but 6'' blocks in the rear just dont seem like a good idea to me. Should i just fork out the extra $$$ for the rear springs? Will Lift springs in the rear ride better than blocks? And are the "EZ Ride" or "Soft Ride" kits really better than standard kits? The front springs on my truck are sagged so much that the springs hit bump stops on just about every bump so anything will ride better.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-29-2010, 06:27 AM   #2
LONGHAIR
Re: Lift kits?
"Front springs and blocks" is far more of an issue than anything. You do NOT want blocks in the front, ever. Just get a 6" spring in the first place.
As far the rear, there are a couple of way to go. The most economical way is with a 2" add-a-leaf and a 4" block. It kind depends upon how hard you intend to drive this truck. If it is mostly street with occasional light off roading, this way is fine.
Or you could go with a full 6" spring lift in the rear, for harder off-road use.
I would not even consider running a 6" block though, the leverage is just too much. You will get wheel-hop problems.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-29-2010, 09:28 AM   #3
baclay9
Re: Lift kits?
Most 6" lifts will consist of 6" springs for the front and 4" blocks for the rear. That way the truck sits level
don't forget to get a drop pitman arm.
baclay9 is offline   Reply With Quote
Old 06-29-2010, 11:30 AM   #4
MTCK
MTCK's Avatar
Re: Lift kits?
Check out www.offroaddesign.com . I've used the shackle flip kit with good results. You can add a leave or use a longer shackle to get up to 6" without replacing your rear springs. They have pretty much everything you could need, including front springs, steering correction parts, shocks, brake lines etc.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-29-2010, 12:22 PM   #5
BigRed76
BigRed76's Avatar
Re: Lift kits?
Sorry for the confusion, I was not planning on using blocks in the front because i know how dangerous that is, i was plannin on using the blocks for the rear.
Zach
Old 06-29-2010, 12:57 PM   #6
Prerunner1982
Prerunner1982's Avatar
Re: Lift kits?
6" lift springs up front.
2" lift springs in the rear with a 4" shackle flip (http://www.offroaddesign.com/catalog/shacklekit.htm).
I would also suggest a steering box brace..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-29-2010, 12:57 PM   #7
BigRed76
BigRed76's Avatar
Re: Lift kits?
I'm still a little confused on what exactly the shackle flip kit does. Does it just move the shackle to the other side of the spring?
Zach
Old 06-29-2010, 01:35 PM   #8
Prerunner1982
Re: Lift kits?
The stock set up has the shackle going UP from the mount to the leaf spring. The shackle flip has the shack going down to the spring, adding lift.
stock the leaf spring end is 4" (approx) above the shackle mount, swap it to 4" below the shackle mount and you get 4" of lift. When you move one end of the leaf spring, lift is 1/2 the amount the spring end moved. 4" above + 4" below=8" / 2= 4".
Did I confuse you more?
Jon
Oklahoma Roll Call
Old 06-29-2010, 02:11 PM   #9
BigRed76
BigRed76's Avatar
Re: Lift kits?
Thanks for the clarification of that. I understand it now and I like the idea.
Zach
Old 06-30-2010, 03:23 PM   #10
BigRed76
BigRed76's Avatar
Re: Lift kits?
Does anyone know if a 4" lift will be high enough to clear 35's or is it better to go with the 6"?
Zach
Old 06-30-2010, 04:04 PM   #11
68Timber
I know the pieces fit
68Timber's Avatar
Re: Lift kits?
That's the way to do it.
2.5" lift will clear 33's, 4" will clear 35's. 6" over 35's is gravy.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-30-2010, 06:00 PM   #12
BigRed76
BigRed76's Avatar
Re: Lift kits?
Is there an advantage with the shackle flip instead of lift springs?
Zach
Old 06-30-2010, 06:14 PM   #13
bikes&bowties
bikes&bowties's Avatar
Re: Lift kits?
more flex and softer ride.... my vote goes to a 4 inch lift.... DIY offroad B52 kit in the front and shackle flip in the rear... smooth sailing from there on out...
bikes&bowties is offline   Reply With Quote
Old 06-30-2010, 08:04 PM   #14
BigRed76
BigRed76's Avatar
Re: Lift kits?
Can i ask why you would go with a 4"?
Zach
Old 06-30-2010, 09:34 PM   #15
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Lift kits?
If I remember right.... if you go more than 4" you have a lot more issues to work around and fix; With 4" you dont have to extend your brake lines or adjust your drive shaft angle. With that said... I stopped at 4" with my 4x4 Blazer I had... and it cleared the 35's on 8" rallys just fine. BUT I also did not do any off roading either...
CLASSIC87' is offline   Reply With Quote
Old 06-30-2010, 10:40 PM   #16
BigRed76
BigRed76's Avatar
Re: Lift kits?
I understand that. I'm not going to be doing any serious off roading, just mild trails for camping and anything i come across in the winter. So i could do 4" springs in the front and do a 2.5" shackle flip w/6" shackles in the rear, sway bar drop brackets, steering arm...and dont have to have extended brake lines??
Zach
Old 06-30-2010, 11:21 PM   #17
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Lift kits?
I'm not for sure with the above set up you mentioned... this is what I did on my 84' Blazer: 4" lift springs and steering drop arm in front, and the back was a simple 4" block. No other adjusts where needed anywhere as a I recall as I installed it myself.
Thread Tools
Display Modes
