Old 06-29-2010, 07:52 PM   #1
Dhartmann
Dhartmann's Avatar
Fuel tank capacity??
So im trying to figure out just how bad of gas mileage im getting. I have a 69 K10 with original tank behind the seat. Anyone know the capacity of these? Any help would be greatly appreciated!
Dhartmann is offline   Reply With Quote
Old 06-29-2010, 07:55 PM   #2
cam.man67
cam.man67's Avatar
Re: Fuel tank capacity??
It's 20 gal, right?
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 06-29-2010, 08:01 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Mines a little over 20 gallons. There were smaller ones of about 16 gallons too.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-29-2010, 08:05 PM   #4
Dhartmann
Dhartmann's Avatar
Im thinkin a 16 gal sounds pretty close. I filled up today almost on 'E' and only got about 14 gals in it..Cheap to fill up but it dont last!!
Old 06-29-2010, 08:31 PM   #5
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
I believe it is 20 gallons. That is the listed capacity of all the reproductions.
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 06-29-2010, 08:41 PM   #6
Dhartmann
Dhartmann's Avatar
Alright great thanks for the replies!
---Blood Sweat and Tears make the truck---
Old 06-30-2010, 12:10 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there were plenty of 16-ish gallon ones. No documentation of it, but there were plenty made.
Old 06-30-2010, 09:37 AM   #8
71tahoe
71tahoe's Avatar
The most I can remember ever putting in my 71 was about 18 gal.
You don't need to know your tank capacity to figure your MPG.
1. Fill it up until the pump cuts off or fill to where you see the fuel level.
2. Drive it and record the miles.
3. Fill it up at the same pump until it cuts off or fill anywhere to the same level.
4. Divide miles by gallons registered on the pump.
If you have a GPS you can determine the percentage the speed is off and adjust the miles by that but these old speedometers are not accurate. I doubt anyone is still running the original size tires.
71tahoe is offline   Reply With Quote
Old 06-30-2010, 10:08 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Exactly -- and for even better accuracy, simply calculate the average of the three most recent fill-ups. This helps reduce any inconsistencies in topping off the tank.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-30-2010, 12:54 PM   #10
mrein3
mrein3's Avatar
I'd word it this way:
1. Fill it up until the pump cuts off or fill to where you see the fuel level write down odometer reading..
2. Drive it until near empty.
3. Fill it up at the same pump until it cuts off or fill anywhere to the same level. write down odometer reading.
4. Miles driven = odometer reading in #3 minus odometer reading in #1.
5. Divide miles driven gallons in #3.
This only works if your speedo is accurate. If your speedo doesn't match a GPS, fix that first then do the above steps.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Thread Tools
Display Modes
