06-29-2010, 08:23 PM | #1 |
1972 Chevy Cheyenne Super
LWB Outer Bedside Panel Removal Tips
I've heard rumors that the outer bedside panels remove with bolts. Is that true? I plan on pulling one this evening and would like to know what I'm getting myself into. What will I need? What are the tricks?
-Clayton 1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen |
06-29-2010, 08:32 PM | #2 |
Between Trucks...
Re: LWB Outer Bedside Panel Removal Tips
There are some welds towards the back at the bed floor by the tailgate. I've heard the bolts can be a bear and it might be easier to tighten them til they break.
Beat it to fit, Paint it to match... |
06-29-2010, 08:39 PM | #3 |
Active Member
If you mean the whole bedside yes that's correct. The outer panels on the bedsides are spot welded on.
I used a hacksaw to cut the welds at the back and then just removed all of th bolts. I broke a few and had to cut a few. Be sure and buy some new replacement bolts before removing the bedside. |
06-29-2010, 09:42 PM | #4 | |
06-29-2010, 10:03 PM | #5 |
Take both inner and outer off together - new one back on the same way
06-29-2010, 10:47 PM | #6 |
Look at the top of the bed beside the tailgate,then open the tailgate and right at the bottom of the bed were the tailgate lays down you can see the edge of the panel and the bed floor meet, there is a weld about 1/2 to 3/4 long and you can take a chisel and hammer and you can cut it lose.
Hope this helps.
Things happen for a reason! |
06-29-2010, 11:00 PM | #7 |
Grandpa in the rustmobile...
bolts at bottom rear stakepocket.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-29-2010, 11:14 PM | #8 |
Here's a video of my bedside showing where I've removed bolts and what I think I have left.
Take a look and let me know if I'm close or where I need to go. Thanks!
06-30-2010, 01:46 AM | #9 |
you are correct on the spot welds.. take the two tailgate things off the bedside on both sides and underneath there are a few bolts that go from the floor to the bedside.. also the wheel well bolts that run along the side of the bedfloor need to come out and all down the side like u mentioned in the video... if it was me id flip the whole bed over and work that way.. everything is bolted on except where u pointed out the welds.. hope this helps.. i had to do one couple months ago.. i had a few bolts spin on me so i wedged in a screwdriver from the floor to under the bedside to give it some tension so they would stop spinning.. it also would help if you could heat them up a little that is if you want to i didnt do that... i just broke each and every bolt off
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-30-2010, 12:03 PM | #10 |
I thought the wheel wells were separate from the beside.
06-30-2010, 12:23 PM | #11 |
Project Junkie! Fishing Poor!!
There are also 4 bolts on each side that bolt the very rear lower panel to the rear cross sill of the bed floor. You will have to lay on your back and look up near the rear corners to see them or remove the taillight assemblies and look down toward the ground and you will see the pointed ends of the rear 2. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-30-2010, 02:03 PM | #12 |
Active Member
07-01-2010, 02:39 AM | #13 |
ya i guess your right.. just thought u were taking it all apart
Thread Tools | |
Display Modes | |
