Old 06-29-2010, 11:27 PM   #1
FL71C10
Converting to power brakes
My 71 C10 has manual brakes. It has no master cylinder on it right now, but does have a proportioning valve. If I want to add PB, what do I need? The bracket, booster, and master cylinder? Do I need a different brake pedal pushrod as well?
I know I can buy a booster and master cyl new from a local parts store, but how much should the booster bracket and brake pedal pushrod cost me?
Will one from a 3/4 ton work?
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 06-29-2010, 11:39 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Converting to power brakes
you need a power booster the brackets and the pushrod
if you need all that you may be better off getting a unit from ccp or something...unless your good at junkyarding or keep a good eye on here..
John
1999 Toyota Tacoma 4x4
Old 06-30-2010, 03:20 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Do you have to change the master cyl? I didn't know there was a difference?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-30-2010, 03:46 PM   #4
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
I grabed a booster, bracket and pushrod from a pick and pay for $30.
Bolted it on about two months ago using my manual brakes master cyl.
It worked great, just make sure you keep track of all the parts of the
lever in the bracket.
Jack_71C10 is offline   Reply With Quote
Old 06-30-2010, 03:50 PM   #5
70STOVEBOLT
Cool. I am going to convert to power but keep the drums all the way around for now. How critical is it to have the braces for the booster? I don't have those yet.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 06-30-2010, 04:17 PM   #6
Jack_71C10
Jack_71C10's Avatar
not sure, but i got those from the junk yard too.
It seems pretty sturdy without them.
Thread Tools
Display Modes
