Old 07-01-2010, 11:18 AM   #1
yote1234
yote1234's Avatar
whats the best/safest insulation for my cab??
i have found lots of threads on insulating our cabs here, but nothing i've read has covered the very important subjects like.
******"health hazards"***** according to some MSDS data sheets most this stuff is bad in extreme heat conditions. and known to cause cancer and other health effects in labratory animals. (im glad im not a lab animal!)
http://www.cofair.com/pdf/msds/QRMat%20Safe%20Data.pdf
******"arizona extream heat" ****** the other important subject is dealing with 122 deg-up temps. i've read where as little as 100 deg temp can produce as much as 160 deg interior temp! also causing the "outgassing" effect. actually melting the product!.
so i would like to hear from all of you whom have knoweledge of a "safe" product.
whats the best? and the safest!?
is it ashfault or butyl product! or just ??
1971 K5 CST Blazer
1951 -3100 5 window short bed 4sp
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 07-01-2010, 11:25 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: whats the best/safest insulation for my cab??
http://lizardskin.com/
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-01-2010, 11:40 AM   #3
cdowns
cdowns's Avatar
X2 on the lizardskin
i love the stuff would never take a backstep to peel and stick stuff after using it
Old 07-01-2010, 03:51 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Honestly, looking over the data sheet, there is nothing I would be worried about. The HMIS Hazard Rating was a 1, which rates as Slight.
I would be willing to bet that any new carpet would likely outgas more and cause more health hazard then the roof sheeting.
Also, not sure about you but I doubt I would be inside a truck cab at 100*+ with the windows rolled up. Either the windows would be down allowing enough air exchange or the A/C would be on and pulling fresh air and the cab temp would be much lower. Heck any gas fumes from the in cab tank would likely kill you first...
FWIW... YMMV
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-01-2010, 04:18 PM   #5
Custom 68
Custom 68's Avatar
? on the lizard skin stuff.
There are 2 different ones one for sound and then the ceramic stuff. Which one have you used and why?
It looks like interesting stuff.
thanks
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-02-2010, 12:46 AM   #6
my67chevytruck
Under Construction
I have friends that have used it and says it awesome. They say it performs and outlasts any other product. I also visited a small hotrod shop, and they use lizard skin exclusively.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Thread Tools
Display Modes
