Old 07-02-2010, 08:51 PM   #1
05crewcab
05crewcab's Avatar
Is this ok??
Anyone advise against running your heater hose from the engine to the radiator? I am bypassing my heater core and did it the cheapest way possible (not that it's right)
Any reason why this isnt a good thing to do?
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 07-02-2010, 08:58 PM   #2
bglad420
bglad420's Avatar
Re: Is this ok??
Defeats the purpose of your thermostat. Which is going to cause you issues, and as well as redirecting the proper flow of your radiator. Why just not put a plug in the block and not have the hose is the proper way to do it.
How did you get that to mount to the radiator?
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50.
bglad420 is offline   Reply With Quote
Old 07-02-2010, 08:59 PM   #3
bglad420
bglad420's Avatar
Re: Is this ok??
Or just run the hose from the pump to the manifold... If it's just a temp thing til you get a new core.
Old 07-02-2010, 09:08 PM   #4
05crewcab
05crewcab's Avatar
Re: Is this ok??
It's mounted to the radiator on the return line nipple from the heater core, or is it the 'hot' line to the heater core? i dont know which is which...
the top hose from the heater core went to the radiator and the bottom hose went to a vacuum thingy and then to the manifold.
1971 C-20 350/350
Old 07-02-2010, 09:13 PM   #5
05crewcab
05crewcab's Avatar
Re: Is this ok??
and, i am not so sure it messes with the natural flow of the radiator since i am just bypassing the heater core with a shorter length of hose...it makes sense in my brain, but that is why I asked!
1971 C-20 350/350
Old 07-02-2010, 09:13 PM   #6
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Is this ok??
Nice to see no one see's the real problem...CHANGE YOUR FUEL LINE!!!
now why not just get a dhut off ..it's nice to shut the core off in the summer too this way you can turn it on an off as needed
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 07-02-2010, 09:29 PM   #7
05crewcab
05crewcab's Avatar
Re: Is this ok??
What's wrong with my fuel line? The filter after the pump? that's on the short list...
i will probably get a plug for the manifold, but what do i get for the nipple on the radiator?
and, hottrucks, what would you recommend for a shut-off? do they make something like that or would i have to home depot it?
1971 C-20 350/350
Old 07-02-2010, 10:04 PM   #8
mvfd70
mvfd70's Avatar
Re: Is this ok??
Biggest problem with your fuel line is it's a rubber line. Not the best of ideas to have a rubber line running over the engine. Rubber + Heat = Melting
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 07-02-2010, 10:35 PM   #9
imholte
imholte's Avatar
Re: Is this ok??
I think he was refering to your fuel filter, glass right? It can break and start a fire.
72' Custom10 4wd 350: Daily Driver
imholte is offline   Reply With Quote
Old 07-02-2010, 10:38 PM   #10
mvfd70
mvfd70's Avatar
Re: Is this ok??
Well that too. I'm still not a fan of a rubber line running from the pump to carb
Old 07-03-2010, 12:50 AM   #11
ERASER5
ERASER5's Avatar
Re: Is this ok??
Old style rubber hose + 10% Ethanol = rotted hose fast. The new injection type hose has a barrier and stands up to heat very well.
The "vacuum thingy" is a water shut off. Hook it up to full vac and it should close. There is a shut off that shut off both lines, I do not know what year it was. I seem to recall it was for a van, but I am not dead sure.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-03-2010, 05:20 AM   #12
cdowns
cdowns's Avatar
Re: Is this ok??
that lazymans rubber fuel line will get you right in the holiday spirit KABOOM, they're great for the burn to the ground syndrome
Old 07-03-2010, 06:25 AM   #13
LONGHAIR
Re: Is this ok??
It must be a later model radiator, they were made that way.
As far as the fuel line, Yeah, I would replace the rubber hose with a nicely formed steel line. The glass filter is not that big of a deal as long as it is well supported, meaning steel line to keep it firm. That glass is pretty thick, heat treated stuff, it's fairly tough. But I wouldn't want it banging around loose on a rubber line.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-03-2010, 08:29 AM   #14
Hottrucks
Hottrucks's Avatar
Re: Is this ok??
Ok you've been torchered enough....
yea there are alot of different ways to shut them off ...check the thread size..then hit the plumbing dept at any hardware store or even home cheapo
the ball valves work well and you can just get a nipple for each end and cut in in the rubber line ( either side) or get something to screw into the block which is better.....you can check any big truck parts places ..ALL big trucks have this shut off
LMAO I said Nipple!!!
this is the style I like best....and yea I know you can get a vacum one but for the summer this is a solid shut off and it keeps the cab much Kooler
Old 07-03-2010, 10:42 AM   #15
sjarrett71
sjarrett71's Avatar
Re: Is this ok??
AutoZone sells the shut off valves too (if you can get a clerk that knows what they are and where to find them)
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-03-2010, 11:20 AM   #16
Shane
Shane's Avatar
Re: Is this ok??
... or just screw in a male NPT plug.
concept of KISS - Keep It Simple Stupid
Shane is offline   Reply With Quote
Old 07-03-2010, 11:43 AM   #17
eagleuh1
eagleuh1's Avatar
Re: Is this ok??
If I can see correctly, his biggest problem is the heater hose is going to his tranny cooler line fitting on the radiator. Wheres the outlet from the tranny cooler going? Hopefully not back to the tranny! Anybody else see this?
eagleuh1 is offline   Reply With Quote
Old 07-03-2010, 11:49 AM   #18
eagleuh1
eagleuh1's Avatar
Re: Is this ok??
My bad, I put my reading glasses on and looked at the pic again. Now I see the tranny line above the hose. Sorry. Did you put that nipple on the radiator yourself? I vote for Kiss, plug it, available at your closest hardware store. Also, visit NAPA and bend up some metal fuel hose and use a metal filter. Not hard to do. Good luck. Whats the rest of the truck look like.
Old 07-03-2010, 12:05 PM   #19
05crewcab
05crewcab's Avatar
Re: Is this ok??
Thanks for the responses guys... it hasnt been torture, yet!
couple questions:
Fuel line. what size metal line should I use, and is there a pre-bent part made to run from the pump to the carb? or should i get braided stainless? Edelbrock carb 1406.
Heater port in the manifold. i decided to cut off the heat permanently. what size plug would I need? Edelbrock performer intake.
Thanks guys
1971 C-20 350/350
Old 07-03-2010, 04:21 PM   #20
raycow
Re: Is this ok??
If you use a plug, you will still have to deal with the radiator end of the hose. Get a shutoff valve instead and leave the hose connected.
Ray
raycow is offline   Reply With Quote
Old 07-04-2010, 01:52 AM   #21
05crewcab
05crewcab's Avatar
Re: Is this ok??
When changing the fuel line, do I have to drain the fuel since the pump is lower than the tank? dont want to find out the hard way!
I plugged the heater port in the manifold with a brass 1/2" NPT fitting and used a 3/4" PVC plug and 4 inches of old heater hose to cap the port in the radiator. This should keep me cool until I can fix the climate controls.
1971 C-20 350/350
Old 07-04-2010, 03:37 AM   #22
bglad420
bglad420's Avatar
Re: Is this ok??
No you dont have to drain the fuel, you'll get a little spillage out of the line but other than that you'll be ok.
Old 07-04-2010, 07:28 AM   #23
cdowns
cdowns's Avatar
Re: Is this ok??
i my experience most times the gas will flow when you remove the line from the pump due to siphon effect// the short rubber connecting hose from the frame rail to the inlet of the pump should b clamped shut
Thread Tools
Display Modes
