07-04-2010, 07:56 PM | #1 |
72 GMC Rad Support Work With...
Just wondering if there were any differences between the 68 GMC support and a 72 GMC support. Trying to find complete good condition GMC (quad buckets) supports has been a pain and I have a chance to pickup a 72 GMC support for a good deal but don't know if I will be able to make it work with a 68 hood/grille etc.
Thanks in advance for any feedback
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
07-04-2010, 10:39 PM | #2 |
Re: 72 GMC Rad Support Work With...
Other than holes cut for air or aux battery brackets they should be the same for the GMC's.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
07-04-2010, 10:53 PM | #3 |
I think I might have one off a 72. I can go take a gander at it and let you know if its anything worth while. I'm just down in Bellingham WA
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
07-04-2010, 10:54 PM | #4 |
Whoops a little backwards there I thought you found a 68 and wanted a 72... drrrr.
07-04-2010, 10:55 PM | #5 |
Member #1049
The 72 GMC core support will bolt on the same, the only difference is the 68 GMC has threaded holes across the bottom front for the lower valance, the 72 support does not.
Thread Tools | |
Display Modes | |
