07-05-2010, 07:32 PM | #1 |
All About the BOWTIE
Trim Removal Questions
Hey Y'all.............
Came across a guy who's parting out an 87 Silverado on Craigslist. Guy said I could buy the trim behind the cab, and the tailgate band with all the clips and such.. for $100,.... thing is... was talking to him on the phone.. to set-up time to check it out, and neither him or I really know how these things come off, don't wanna just start prying stuff off...fact is.. I'm new to this type of stuff.. I learn as I go.. but really am getting into sweetening my truck up, thanks to you all... any experienced advice with this... also, my truck never had the trim, and tailgate band to begin with (Custom Deluxe),.. the tail-gate band i'm curious about, is there clips behind it, that it goes onto?..... how tough is it to mount on a truck that never had it? Thanks alot in advance..... could really use the tips - CaliDude
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 07-05-2010 at 07:44 PM. |
07-05-2010, 08:25 PM | #2 |
Getting Old; Going Broke
Re: Trim Removal Questions
The tailgate band is easy. There are like 4 bolts on the backside of the tailgate, all the clips are on the band itself. Just grab the band and bolts and look at where the holes are, or make yourself a template. Drill some holes and install.
The molding on the cab and cab corners is just about as easy. The corner moldings are held on with a nut, it is on the inside of the cab corner. You can fish your hand up in there and feel the nut fairly easy. Once you get the corner moldings off, you can literally slide the long cab molding off in either direction. It is held on with simple pressure clips. |
07-05-2010, 09:21 PM | #3 | |
I'm putting it on my truck from scratch... dont wanna buy it, if i can't put it on my truck correctly...
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 07-05-2010 at 09:34 PM. |
07-05-2010, 09:40 PM | #4 |
You'll be able to get the clips off by sliding them off of their studs, it'll make sense when you see it. The clips are held on with studs, but you can use screws or rivets to install the clips on your truck.
I could be thinking of el camino moldings though, it's been 15 years since I had one apart. But I'm fairly confident in my answer. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=46 #7 is what holds the corner pieces on, has a bolt going through the cab corner with a nut on the back (inside). #4 holds the long piece on across the back. You can actually press the molding down and get the bottom edge to pop off, instead of sliding it off. I just always found it easier to slide it off, less chance of bending it but more of a chance of breaking the clips. Last edited by RandyP; 07-05-2010 at 09:45 PM. |
07-05-2010, 09:53 PM | #5 | |
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 07-05-2010 at 09:56 PM. |
07-06-2010, 05:41 AM | #6 |
If your truck did not come with the trim (ie. custom deluxe) then you will not have the studs on the back of your cab to attach the clips for the molding under the back window. Likewise, you probably won't have a hole drilled through your pillar for the corner piece.
07-06-2010, 06:05 AM | #7 |
What would keep a guy from sticking all of this on with 3M tape. Assuming you don't already have the holes?
07-06-2010, 07:49 AM | #8 |
The trim has huge lips on top and bottom, not much of a surface to put two sided tape on. You would have to build the tape up a few layers to get it to work like that really. It's very easy to put the clips on and to make a hole for the corner trim.
07-06-2010, 07:53 AM | #9 |
i used two rolls of 3m tape and went around the outside edge of the trim. and i swear im not crazy but mine did not have the holes going through bolting it to the cab..
"I'll keep my guns, money, and freedom. You can keep the "change" |
07-06-2010, 08:05 AM | #10 |
What a truck is supposed to have and what trucks have currently, two different things sometimes.
07-06-2010, 11:38 AM | #11 |
I suppose I better measure twice, and drill once... I'll measure the holes and spacing off of the donor truck.... can't have the trim coming out all crooked.....
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 07-06-2010 at 11:39 AM. |
07-07-2010, 12:33 AM | #12 |
Just to clarify. Yes you could use tape to attach the aluminum trim, I would certainly recommend drilling a hole for the corner pieces, as the factory did.
As for "using the clips" that is impossible if your truck did not come with the little posts on your cab. If you don't have the posts sticking out, the clips have nothing to hold on to. Also, if your cab has no hole drilled into the side pillar to hold the corner trim, then your cab did not come stock with the aluminum trim package. Someone would have to have stuck on the corner trim with tape in another life. Cheers |
07-07-2010, 08:42 AM | #13 | |
07-07-2010, 11:03 AM | #14 |
That's what I was thinking too.... I figured the "posts" on the back of the cab were just an easier way to mount and align the back trim piece.. I was looking at the clips they use in my LMC book.. and I can see where they have holes and screws where it mounts to the cab, and the center hole where it could possibly slide on the post too.. sort of a universal type deal....thought about using 3M double tape... but doesn't seem durable enough for time. Has anyone actually done the aftermarket drilling and clip adding?
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
07-07-2010, 04:59 PM | #15 |
I haven't put trim on but I just took mine off. The little posts seemed to me to just be little rivots that had extended posts on them. To me it shouldn't be too hard to put the trim on. Just take all the measurements for the holes from the donor truck, mark out the holes , remeasure and drill the holes. I wouldn't use tape due to the backside of the molding having the lips on them and I doubt it would actually hold it how it should. Hope this helps!
1984 GMC 1500 2WD Big plans in the making |
07-09-2010, 12:36 PM | #16 | |
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 07-09-2010 at 12:39 PM. |
07-09-2010, 11:35 PM | #17 |
I put the trim on today.... check it out.... http://67-72chevytrucks.com/vboard/s...d.php?t=411235
Thread Tools | |
Display Modes | |
