07-12-2010, 01:38 AM | #1 |
305 to 454 swap
Hello everyone, I'm new to the forum. Been lurking around for awhile as a guest and I must say this is one of my favorite sites for the square body trucks.
Anyways, I have a 1979 GMC 1/2 ton 2wd with the old and slowly getting tired 305 in it and I am wanting to do a 454 swap into this truck. This will be my first engine swap in a square body and I am wondering if this is going to be a direct bolt in, or will I have to modify the engine mounts to put this engine in? Also will the old Turbo 350 tranny be a good transmission for this swap? Thanks, BBC Chevy Man |
07-12-2010, 02:16 AM | #2 |
Re: 305 to 454 swap
Another new guy here, but as far as I know you shouldnt run into any problems with mounts. Ive been involved with a couple bbc swaps in these trucks but as far as i can remember you shouldnt have a problem. Th350 as long as it is a good trans will be fine, Ive had several behind bbc's that did fine.
07-12-2010, 08:15 AM | #3 |
No No
Re: 305 to 454 swap
It will drop right in no issues. Just make sure you have all the parts and accessories to make it work. The 305 cooling system may not like the bigger engine but the TH350 should hold up just fine as long as there are not current problems with it.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
07-12-2010, 10:46 AM | #4 |
Re: 305 to 454 swap
Thanks guys. The 454 is coming from a 1978 chevy crew cab donor truck, so I'll have all the parts I'll need for the swap between the two trucks.
07-12-2010, 05:35 PM | #5 |
Re: 305 to 454 swap
Could i do the same, but with TBI(since mine is an 87)
1987 GMC Wrangler - 305TBI/TH400/Duals 1968 Camaro - Resto 2010 Ranger I only drive truck 6 months a year... Dam Canadian winters.
07-13-2010, 12:24 AM | #6 |
Re: 305 to 454 swap
From what i can remember the TBI isnt really an issue to swap either. The only TBI swap Ive done was swapping out a 4.3 for a 5.7 and it was a peice of cake no wiring to swap. Someone else that has done this could chime in a correct me if Im wrong on it not being an issue to swap in a tbi 454
07-13-2010, 06:28 PM | #7 |
Re: 305 to 454 swap
I swapped a 454 into a '79 Suburban that had a SB400.It bolted right in.But a couple of issues were the stock 454 tall fuel pump didn't fit.The stock 454 cross members and motor mounts mount the engine higher up.I ended up using a shorter pump out of a '70 Malibu with a BB in it.Also the stock cooling didn't cool it enough.I had to find a BB radiator.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
07-13-2010, 06:34 PM | #8 |
Re: 305 to 454 swap
Is the 454 TBI now?The stock 454 TBI is bigger and the ECM is programmed for this.Also is the 454 from in front of an auto or manual.The ECM controls the shifting of the auto.So if the ECM is from a manual you may have problems with the shifting if it will shift at all.
Check out the TBI swap thread here.It has great info!You will see I have been asking lots of questions there.
07-14-2010, 01:59 PM | #9 | |
Re: 305 to 454 swap
Well First off the motor mounts were diffrent for the 4.3 and 350 the 4.3 harness was 2or 3inches to short so i ended up using a tbi harness from another parts truck that came with a v8 the 4.3 to 350 swap was ok not all that hard but make sure u have a complete parts truck to use as i also found out that the 4.3 power steering pump braket was diffrent than a v8
CANT RESCUE ALL OF THEM BUT I CAN SURE TRY 1987 Gmc Sierra swb 2wd (soon to have a TBI 454) 1987 Custom Deluxe 2wd (Was a TBI 4.3 V6 Now TBI 5.7 350) DAILY DRIVER 1985 MILITARY CUCV M1008 Pretty much Stock 1987 3/4 ton GMC 2wd Suburban TBI 7.4 454(DONOR FOR 87 GMC SWB) BEING USED AS PARTS 1989 GMC SUBURBAN TBI 5.7 350 (MOTOR IS NOW IN 87 CUSTOM DELUXE)BEING USED FOR PARTS Gets More Chicks =GMC Got More Cubes=GMC Got My Chevy=GMC God Made Chevy=GMC |
07-14-2010, 02:14 PM | #10 |
Re: 305 to 454 swap
anyone done a 572 swap ?
1986 LWB C-10 305/th400 Daily Driver and beer runner |
07-14-2010, 05:29 PM | #11 |
Re: 305 to 454 swap
I don't have the motor... lol, i was just wondering what would be easier. Was considering the 327 carbed i haqve laying in the garage rebuilt. But alot of work to get it to work, done lots and lots of research on that. Just wondered if a 454 with tbi would be easier. These are plans for down the road.... way down the road. Thanks, though.
07-14-2010, 05:55 PM | #12 | |
Re: 305 to 454 swap
Chime in anyone who has an 87 th400... i am possitive that its not ecm controlled, no?
07-15-2010, 12:46 PM | #13 |
dang its hot
Re: 305 to 454 swap
a donor vehicle for all the widgets and brackets make life so much easier...
Thread Tools | |
Display Modes | |
