07-17-2010, 06:44 PM | #1 |
cooling problems
ok i am alittle new to all of this. i have a 72 cheyenne with a 95 tbi crate motor and i cant seem to keep it cool. i have changed the thermostat, the water pump, put a 5 core radiator in. any ideas?
07-17-2010, 06:51 PM | #2 |
Re: cooling problems
Assume you verified the over heat problem with an IR gun. These old gauges can not be trusted. Verifiy and let us know what the temp is running. Several things to check: make sure the lower hose is not suctioning closed, if you have a fan clutch is it working (should be able to hear it roar when it locks up during hot conditions). What water pump did you out in it, new, rebuilt, what brand?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-17-2010, 06:55 PM | #3 |
20' Daredevil (Ret)
Welcome from NorCal!
Do you have a fan shroud? What type of fan? When does it run hot -- when idling, at low speeds, at highway speeds... or always? Do you know if your gauge is accurate? Does the truck have the right pressure cap? Do you have 50/50 antifreeze mix in it?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 07-17-2010 at 06:56 PM. |
07-17-2010, 08:07 PM | #4 |
when i want to know for sure i put a thermometer in the coolant to verify temp
07-17-2010, 10:09 PM | #5 |
Junior Member
Are you running the serpentine system or the old v-belt. I maybe wrong, but I think the '95 fan/water pump runs the opposite of the older 350s. I wonder if the water pump is running in the wrong direction.
I may be off base, but it is something to check.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
07-17-2010, 10:10 PM | #6 |
You didn't by chance put a water pump in for a serpentine system did you? They run backwards from a v-belt pump.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
07-17-2010, 10:17 PM | #7 |
Never Ending Projects
My thoughts, either wrong water pump (spinning wrong way) OR if you are using the serpentine belt system, are you using the stock fan? If so, the fan is spinning backwards. You would need a fan from a late model truck that was a reverse pitch.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thread Tools | |
Display Modes | |
