07-18-2010, 12:04 PM | #1 |
shock help plz
my 67 is bagged and notched, not sure how to do the shocks, and what shocks to use? little help guys
it usual better and faster if u figure it out yourself!!!! |
07-18-2010, 12:54 PM | #2 |
low n' slo
Re: shock help plz
pics? i ran the stock part number shocks on mine, got them from oreilly. just welded new shock tabs on the axle and bridge bar of my notch.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
07-19-2010, 04:16 PM | #3 |
Re: shock help plz
I am in the same spot. I found the relocator kits, I'm just worrying about blowing out the shocks due to to much compression/extention.
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
07-19-2010, 04:25 PM | #4 |
Re: shock help plz
are you talking front or rear shocks, if the front what control arms /spindles did you use?
The rears is easy, just take you shock perches under the u bolts and flip and reverse them (once you flatten the lip) and get some upper relocators, or you can do a search on here and theres a thread that shows how to modify and use your factory upper shock mounts in the rear.
1967custom |
Thread Tools | |
Display Modes | |
