Old 07-20-2010, 12:18 PM   #1
baller5040
baller5040's Avatar
getting to the gas tanks?
I have search many of the threads here and i'm pretty new to the whole mechanics things but would like to get my truck running and in good shape. I have a 1982 chevy short bed and i have the two tanks as many of you already knew that. I had one tank that read past full on the gas gauge but the other one worked fine until the other day and now it has gone the same route of the other tank. I was looking at both the tanks to find out if maybe the ground went out on them and to replace them. But the problem that i am running into right now is that I have no idea how to go about getting to those grounds. I was thinking about taking the tanks off all the way then I looked at the and looks like a hassle. So I was curious if anyone would know of a better way of getting to those sender units to replace those ground wires.
baller5040 is offline   Reply With Quote
Old 07-20-2010, 12:26 PM   #2
SS Delux
SS Delux's Avatar
Re: getting to the gas tanks?
the only other way at getting at them without dropping the tanks is to get a case of beer, call some friends up and take the box off.
SS Delux is offline   Reply With Quote
Old 07-20-2010, 12:46 PM   #3
baller5040
baller5040's Avatar
Ya I thought of that but what a pain that would be. So i'm guessing my only option is to go at it to drop them down to get to those ground wires?
Old 07-20-2010, 12:48 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
It is easier to take the bed off. Dropping the tank(s) is a major PITA compared to setting the bed off.
A good engine hoist and some 2x4's and you can do it real easy by yourself. Or a lift or an A frame and some chain and a hoist.
RandyP is offline   Reply With Quote
Old 07-20-2010, 01:14 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I'll just repeat what they said. It is MUCH easier, and faster, to take the bed off to get to the sending unit wires. Then, if you do need to pull the tanks, it will be much easier still to unhook the hoses and wires with the bed off, and then pull the tanks. On a short bed, if you need to pull the sending units out, you will need to drop the tanks anyhow, and it will far easier to do that with the bed gone.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-20-2010, 01:27 PM   #6
Rogue_Sentinel
Rogue_Sentinel's Avatar
take the bed off , you have two gas tank. you can fix both at the same time, the first time.
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final."
Hunter S THompson
Rogue_Sentinel is offline   Reply With Quote
Old 07-20-2010, 01:30 PM   #7
baller5040
baller5040's Avatar
taking the bed off do i have to take all the wiring for the tail lights and so on out too?
Old 07-20-2010, 01:34 PM   #8
glock35ipsc
No, the harness unplugs in the rear. Somewhere above the bumper, between the drivers side frame rail and the bed.
Bob
Old 07-20-2010, 01:39 PM   #9
MONTEZ
I say shoot the rabbit, shoot the duck. Your bed bolts may be just as much of a pain as dropping the tanks. If you drop the tanks by unbolting the strap bracket from the frame it is 100 times easier than unwrapping the strap from the tank. I think it's four bolts per tank and it comes right out. Put it back the same way with the use of a jack to help line your holes up and go to town. If you unwarp the strap then yes it will be a major PITA.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 07-20-2010, 03:58 PM   #10
baclay9
I am on the "take off the bed" wagon. Sooo much easier.
baclay9 is offline   Reply With Quote
Old 07-20-2010, 10:21 PM   #11
6772fan
Active Member
6772fan's Avatar
Another vote for taking the bed off. I've done it both ways and believe me, it's much easier removing the bed.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 07-20-2010, 11:12 PM   #12
MONTEZ
I guess I'm just used to beds taking 2-3 hours to get off. I can drop both tanks in 30 min and have em back on in about 45.....
Old 07-21-2010, 01:36 AM   #13
SS Delux
SS Delux's Avatar
If you plan on taking either off, make sure to use a quality penitrating oil to avoid snapping bolts. Once you have snapped a bolt your whole day goes to hell.
Old 07-21-2010, 01:46 AM   #14
cableguy0
Unbolting the brackets from the frame and just dropping the whole deal is far easier than pulling the bed. An almost empty tank weighs a few pounds. A bed weighs a few hundred pounds. Take the filler neck hose off the tank and disconnect the fuel lines after the tank is loose.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-21-2010, 08:47 AM   #15
Davidmichael
Davidmichael's Avatar
I say do this. I just dropped a tank in my 81. I unbolted the whole assembly, and let me tell you it was a breeze. I think I had 4 bolts on the back, and 2 on the front. Now you will have to get a jack and make sure the tank does not come crashing down and rip the hose/wires from the sending unit. But by far the easiest way I have found as of yet.
as for the filler neck, mine had 2 screws holding it on behind the door and I just unscrewed them and took the entire hose and cap with the tank.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 07-25-2010, 02:06 AM   #16
iroc12valve
I'm on the pull the bed train, but i've never done a short box so my .02 is really .005
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Thread Tools
Display Modes
