Old 07-25-2010, 09:14 AM   #1
51 68CHEVY
Question swap 68 6 lug to 5 lug
I have a 1968 6 lug 373 posi rear that I would like to make a 5 lug.Is it best to redill the pattern to 5, or can I use like 71 5 lug axles, and get them cut down and regroved.and what drums would I use?I want the 68 rear because it is 3 inchs shorter than the 71 rear.What i have is i'm putting a 1954 chevy 3100 series on the 68 frame.
51 68CHEVY is offline   Reply With Quote
Old 07-25-2010, 11:02 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: swap 68 6 lug to 5 lug
I believe the rearend is only 1.5" narrower. (3/4" per side)
You can buy aftermarket axles or redrill your axles.
If you redrill your 6 lug axles at least 1 lug stud hole will have to be welded up. Also the center hub of the axle will have to be turned down to match the smaller bore of the 5-lug brake drums.
I would use 71-72 brake drums.
Keith
Convert to disc brakes.
Old 08-05-2010, 08:42 PM   #3
chris mc bride
chris mc bride's Avatar
IMO you would be better just buying a new set of axles. If its only 3/4 diffarance you might be able to have yours cut. The cost of new ones are probely not that much more,plus you know you have a good piece under your but when your clicking down the highway and if like me probaly near the tripple digit mark.
chris mc bride is offline   Reply With Quote
Thread Tools
Display Modes
